Input Driver: Append Feature Problem
shekh
Posted: Jan 4 2015, 03:08 PM
I was able to implement it, but there are some problems.
Please improve plugin interface so that Append could be implemented properly.
When the file is opened with "auto scan" option, I can mimic VD segment detection and append several files. This works.
But when I use "append avi segment" the problems begin.
1) (minor) The file open dialog shows wrong file pattern (avi). Should be the plugins file pattern/title etc.
2) The timeline is not updated after successful append.
This requires changes in VD source, I put this function and the thing seems to work (not tested everything yet):
void VDVideoSourcePlugin::streamAppendReinit() {
 vdwithinputplugin(mpContext) {
   IVDXStreamSourceV3 *xssv3 = (IVDXStreamSourceV3 *)mpXS->AsInterface(IVDXStreamSourceV3::kIID);
   if (xssv3)
     xssv3->GetStreamSourceInfoV3(mSSInfo);
   else
     mpXS->GetStreamSourceInfo(mSSInfo.mInfo);
 mSampleLast = mSSInfo.mInfo.mSampleCount;
 streamInfo.dwLength = VDClampToUint32(mSSInfo.mInfo.mSampleCount);
3) (very minor) If the formats of segments are different, they cannot display.
Would be perfect if VD could accept dynamically changing pixmap format/layout.
I display error message at decoding, not bad.
0 replies since Jan 4 2015, 03:08 PM Track this topic | Email this topic | Print this topic
