1.10.2 is now out. There are no new changes since the last 1.10.1 test release, for those of you who have been following that thread.
| CODE | VirtualDub CLI Video Processor Version 1.10.2 (build 34807/release) for 80x86 Copyright (C) Avery Lee 1998-2009. Licensed under GNU General Public License
Build 34807 (1.10.2, experimental): [June 3, 2012] [features added] * Added option and /[no]useprofile switch to store configuration files under the user profile. * Added option for fully buffered write I/O. * PluginAPI: The preferred fccHandler supplied by input plugins is now also passed through to output files. * Decoders: Relaxed size restrictions on MJPEG decoder since a more flexible conversion blitter is now being used.
[bugs fixed] * The priority of the ASF pseudo-handler has been reduced to allow plugins to handle the format. * Fixed .exe manifest embedding error. * "Export raw video" command now saves properly in job scripts. * Fixed inversion when reading TARGA images (regression from 1.10.1). * Fixed bug that caused occasional truncated audio when writing segmented AVIs. * ExtEnc: Fixed omitted parameters and occasional extra commas when exporting profiles. * Filters: Fixed artifacts in 2:1 filters in 64-bit build. * Filters: Fixed logic errors in HSV adjust and emboss filters. * Filters: Lowered GPU priority in D3D9Ex acceleration mode to improve system responsiveness. * Filters: Restored missing perspective filter. * Filters: Fixed chroma smoother filter. * HexViewer: Fixed incorrect text label for fccHandler stream field. * Capture: Added timeout check for screen capture driver to avoid locking up program totally when capture load is too high.
