Virtualdub 1.9.1 Released
Posted: Mar 28 2009, 11:40 PM
Build 31536 (1.9.1, experimental): [March 28, 2009]
  [features added]
  * Render: Audio buffer size is now tunable in Options > Preferences.
  * Render: Blitters are now cached for additional speed.
  * Render: Performance sub-panel of status window now shows more
    appropriate stats.
  * Render: Navigation keyboard shortcuts now work during preview.
  * Filters: IVTC is now a video filter.
  * Filters: Convert format filter now has options for UYVY and YUY2.
  * Filters: Field swap now supports YCbCr formats.
  * Filters: The filter system now automatically prerolls forward to
    compensate for filters with a lag (delay from input to output).
  * Filters: New interlace filter to generate interlaced video.
  * Filters: New interpolate filter to resample to different frame rates
    with blending.
  * Filters: Added ELA, Yadif, and frame rate doubling modes to deinterlace
    filter.
  * Filters: The filter system is now better at detecting and reporting
    errors in filters.
  * Filters: Fixed overrun crash in box blur filter if radius exceeds size
    of image.
  * PluginAPI: Video filters can request multiple source frames per output
    frame.
  * PluginAPI: Video filters can request aligned scanlines.
  * PluginAPI: Video filters can initiate direct bypass for frames during
    smart rendering.
  * Capture: Fixed wrong area captured by screen capture driver with OpenGL
    acceleration enabled, rescale on, and mouse pointer capture enabled.
  * Display: Added options for zooming to 12%.
  * UI: Added Ctrl+Shift+F7 as a shortcut for batching Save AVI.
  * UI: Preview no longer sticks if you seek to the end of the timeline.
  * UI: Curve editor position now updates at end of timeline.
  * AVI: Added DVSD to list of video formats that only have key frames.
  [bugs fixed]
  * Audio duration in File Information was incorrect for VBR audio streams.
  * Fixed crashes with test videos when input color format was set to 4:4:4
    YCbCr (YV24).
  * Audio display now updates after preview stops.
  * Decoders: MJPEG decoder was decoding blocks in the wrong order for 4:2:0
    mode.
  * Decoders: MJPEG decoder didn't safely handle corrupt data having skip-16
    codes overruning the coefficient matrix.
  * Filters: Fixed cases where resize filter was not using fast paths for
    1:1 resampling along an axis.
  * Filters: Fixed crash in warpsharp filter due to out of bounds
    displacement vectors.
  * Filters: Fixed script error when loading configurations with warpsharp
    filters.
  * Filters: The filter system no longer tries Y8 before other YCbCr formats
    if the filter cannot support a RGB32 source.
  * Filters: The resize filter was using incorrect border fill colors for
    4:4:4 YCbCr (YV24) input.
  * Capture: Frame rate changes in filters are now respected.
  * Display: Panes could get stuck in GDI mode if auto-fallback mode was
    disabled.
  * Display: Reduced CPU usage when GPU queue becomes full in Direct3D mode
    with vsync off.
  * Display: You can no longer resize panes below 1x1.
  * Render: "Show decompressed output" no longer misses the very first frame
    if activated at the start of a render.
  * Render: "Show decompressed output" wasn't using internal video decoders.
  [regressions fixed]
  * Filters: Sampling with levels filter didn't work when the input format was
    YCbCr (since 1.9.0).
  * Filters: Filter preview broke when toggling luma mode on levels filter
    with YCbCr input (since 1.9.0).
  * Filters: Fixed cropping bug where tall, narrow videos didn't crop properly.
  * Filters: Brightness/contrast filter was broken for RGB32 input (since
    1.9.0).
  * Render: Fixed smart rendering issue that could cause broken frames at the
    start of a new processed section (since 1.8.1).
  * Fixed a rare crash when doing YUV to RGB conversion on SSE2 capable
    systems (since 1.9.0).
  * Settings saving in the Save Segmented AVI... dialog was scrambled (since
    1.9.0).
  * Fixed an off-by-one error in the frame count limit for segmented saving.
Posted: Mar 29 2009, 12:14 AM
Tools - Performance - Audio Buffering
Set to 64 seconds, close virtualdub, open virtualdub, setting is now on 1 second
Lower values work as expected
Posted: Mar 29 2009, 12:23 AM
Probably just a bug in the lookup routine -- will fix in 1.9.2.
ddummer
Posted: Mar 30 2009, 03:32 PM
Preview starts at current frame: Much appreciated!
Another donation was made...
//Daniel biggrin.gif
tarpid25
Posted: Jun 26 2015, 11:17 AM
pearl strands
niche related links
4 replies since Mar 28 2009, 11:40 PM Track this topic | Email this topic | Print this topic
