My Notes On Compiling Vdub With Vc++ 2008 Express, Could be helpful for newbies, like me
Posted: May 24 2012, 11:32 PM
Checking the source of Asuka, it does return 0 unless there's an error, but none of it's error values =1
Otoh, (here) there are some doubled up slashes being passed in the filenames
Are the 2010 runtime libraries more sensitive about them?
In the rules, OutputPath was
$(ProjectDir)\autogen\
and to get rid of the doubled slashes it could be changed to
$(ProjectDir)autogen
The good thing is that you can modify psa.cpp for debugging the compile
eg adding a messagebox in the function tool_psa to show the passed file names
levicki
Posted: May 25 2012, 09:46 AM
This is important news and it is related to this topic so I put it here:
http://arstechnica.com/information-technol...d-on-windows-8/
It won't be possible to use Visual Studio 11 Express to create and compile desktop applications.
Regarding the slashes I have seen only one situation where VS2010 insists on having trailing slashes (for OutDir and IntDir if I remember correctly).
Posted: May 27 2012, 08:50 PM
Anyway, thanks phaeron - that cast did the trick. Well, for that bit anyway - VC++ 10 makes compiling VDub a lot more complicated. I had to put src/ in the root of C:\ to get anywhere - some kind of path macro problem? I also had to run all of the "asuka.exe psa" commands myself on the command line, because they all "exited with code 1".
The VS2010 project converter is pretty broken and you have to fix up the projects afterward. The problem with files getting dumped in or referenced from the root is caused by property sheet ordering issues -- VS2005/2008 is order independent, MSBuild is not. Reorder the project property sheets in the Property View to fix the problem. I already did this in the 1.10.x sources, but you need to fix this up for 1.9.x.
Backslash issues are due to another ill-advised change, which is that MS decided that the $(IntDir) and $(OutDir) path macros should end in a backslash. I don't know why, because the OS path variables don't have this and it breaks command lines that use quotes around the paths, i.e. "$(IntDir)" and "$(OutDir)". Remove the backslash from the intermediate and output directory settings in the project to fix.
command line -> "..\..\out\Debug\asuka.exe" psa "f:\VSProjects\VirtualDubProjects\Virtualdub\src\VirtualDub\VirtualDub.vcproj" "f:\VSProjects\VirtualDubProjects\Virtualdub\src\VirtualDub\\autogen\\VirtualDub.inl"
Err, this is totally wrong -- it is trying to compile the project file itself. I'm trying to remember what needed to be changed in the PSA rules file... the VS2010 custom build rule converter has tons of bugs.
Altaf
Posted: Feb 26 2014, 08:26 AM
Первый вариант VD я собираю. Как собрать вариант VD - AMD64?
I collect the first VD option.
How to compile VD option - AMD64?
18 replies since Nov 17 2009, 04:07 PM Track this topic | Email this topic | Print this topic
Pages: (2) 1 [2]
