| Sarreq Teryx |
| Posted: Dec 10 2002, 10:37 AM |
VirtualdubMod Alpha tester
I just opened VD 1.4.13build14328 and got this error message:
Note: The terms of the End-Users License Agreement for Visual C++ Introductory Edition do not permit redistribution of executables you create with this Product.
It leaves VD running, but I'm pretty sure I shouldn't be getting that message.
| Sarreq Teryx |
| Posted: Dec 10 2002, 10:40 AM |
on second look, I'm thinking it may be the cartoon cleaner just posted in the filters room, so I probably posted this in the wrong place.
| Fredrik |
| Posted: Dec 10 2002, 04:32 PM |
| QUOTE (Sarreq Teryx @ Dec 10 2002, 04:40 AM) | | on second look, I'm thinking it may be the cartoon cleaner just posted in the filters room, so I probably posted this in the wrong place. |
It definitely IS the cartoon cleaner. Just delete the SIMPSONS.VDF file from vd\plugins and you should get rid of the message - and the filter, of course |
| Sarreq Teryx |
| Posted: Dec 11 2002, 03:29 AM |
already did that, the filter wouldn't load anyway
| Fredrik |
| Posted: Dec 12 2002, 01:13 AM |
| QUOTE (Sarreq Teryx @ Dec 10 2002, 09:29 PM) | | already did that, the filter wouldn't load anyway |
Hm? That's strange... you mean it did not appear in the filter list? |
| Sarreq Teryx |
| Posted: Dec 12 2002, 12:19 PM |
not at all
| Fredrik |
| Posted: Dec 12 2002, 05:11 PM |
| QUOTE (Sarreq Teryx @ Dec 12 2002, 06:19 AM) | | not at all |
That's strange, it works here. |
| jcsston |
| Posted: Dec 12 2002, 06:09 PM |
Matroska Dev
It's works on mine too. I had both versions v0.1 v0.2 loaded at the same time, so the dialog came up twice.
| Fredrik |
| Posted: Dec 13 2002, 12:07 AM |
| QUOTE (jcsston @ Dec 12 2002, 12:09 PM) | | It's works on mine too. I had both versions v0.1 v0.2 loaded at the same time, but the dialog came up twice. |
Replace "but" with "so", that increases the logic ;-)
Could you compare the performance of 0.1 <-> 0.2 ? Just interested.
| jcsston |
| Posted: Dec 13 2002, 03:04 AM |
Matroska Dev
On a 11:23 RGB Huffyuv avi file the times were almost the same 20:55 v0.1 20:56 v0.2 The v0.1 file was slightly smaller in filesize.
