| ale5000 |
| Posted: Feb 18 2015, 03:39 PM |
Many input plugins support direct stream copy and output video and audio data in avi-compatible way, so I think VirtualDub should allow "append avi segment" for all supported formats only checking if the video and audio is in the same format, not the container.
Is it possible?
| shekh |
| Posted: Feb 19 2015, 11:26 AM |
Just my 5 cents In the code, at first glance, the internal formats are implemented in a way incomatible with input plugins. This is unlike video filters which realize the same interface as external plugins. Currently each input driver may implement its own "append" but there is no stucture to connect multiple drivers. |
| ale5000 |
| Posted: Feb 19 2015, 07:56 PM |
I'm not talking about all input plugins, I'm talking in particular about fccHandler's input plugins that allow direct stream copy and use VFW/ACM for decoding.
I can direct stream copy some mkv files to avi with VirtualDub then reopen them as avi and append, but I would prefer doing it in one step. Obviously this would never work with DirectShow and FFDShow input plugins.
