Input Vs Output Panes
shekh
Posted: Dec 17 2014, 09:00 PM
Just noticed that when I click "play input" the pixel format is temporarily changed to RGB for the duration of playback.
This does not happen with "play output". Without any plugins both panes seem identical. Does it have simple explanation why they behave differently?
I began to switch to input pane once I realized that "scan scene" buttons actually do something.. again what is the explanation they dont work with output pane?
Posted: Dec 17 2014, 09:09 PM
1) Change to RGB during playback
I don't know for sure, but verify in VirtualDub, via the Options-menu > Preferences > Main, that the "Output color depth" is set to "Match display depth" instead of "Fastest (16 bit)".
2) Scan for scene change
I suppose that this is "by design". It has no use to search for a scene change in "two" panels that are displaying the same video at the same time, ... one panel should be sufficient for that.
Posted: Dec 17 2014, 09:35 PM
On play input, virtualdub just decodes to the screens format (rgb) as it doesn't use the filter list at all, so doesn't have to do any conversions etc
On play output, the frames traverse the filter list and go through all the implicit conversions
Basically it's just an optimization
Scan scene's just for quickly finding scene changes and fades
It's pointlessly expensive to traverse the filter list, plus filters could stop it working altogether
eg
you may blend a fill to produce a fade in, then scene scan to where you want to do a fade out
If it operated on the output, then it'd never find the scene change as it's all black now
You have to remember that the filter list may be incredibly slow, it may have IVTC, temporal cleaners etc that all do a lot of seeking to produce just 1 frame of output
If it can be avoided then that's normally a good thing
shekh
Posted: Dec 17 2014, 09:51 PM
Interesting.
The default "0" format is selected during still frame and scene scan, but only when I click "play" it is changing to rgb "7".
Changed the option Preferences->Output color depth to "use output setting".
The selected format changed to "0"!
But it does not play. I got message:
The current output video format is not supported by the selected output path.
For the scene scan I didnt mean to scan filter output, just the same thing but apply filters on top. Makes sense when output is the only visible pane.
Posted: Dec 17 2014, 10:01 PM
Best thing's to check the sourcecode
Play input, it's hardcoded
switch(g_prefs.main.iPreviewDepth) {
case PreferencesMain::DEPTH_DISPLAY:
  DEVMODE dm;
  dm.dmSize = sizeof(DEVMODE);
  dm.dmDriverExtra = 0;
  if (!EnumDisplaySettings(NULL, ENUM_CURRENT_SETTINGS, &dm))
   dm.dmBitsPerPel = 32;
  switch(dm.dmBitsPerPel) {
  case 24:
   dubOpt.video.mInputFormat = nsVDPixmap::kPixFormat_RGB888;
   break;
  case 32:
   dubOpt.video.mInputFormat = nsVDPixmap::kPixFormat_XRGB8888;
   break;
  default:
   dubOpt.video.mInputFormat = nsVDPixmap::kPixFormat_XRGB1555;
   break;
 break;
case PreferencesMain::DEPTH_FASTEST:
case PreferencesMain::DEPTH_16BIT:
 break;
case PreferencesMain::DEPTH_24BIT:
 break;
// Ignore: PreferencesMain::DEPTH_OUTPUT
dubOpt.video.mOutputFormat   = dubOpt.video.mInputFormat;
You could add a request to phaeron for scene scan to work on the output pane if it's the only visible one?
4 replies since Dec 17 2014, 09:00 PM Track this topic | Email this topic | Print this topic
