Virtualdub Icon, Replacement app icon for VirtualDub
Neo Neko
Posted: Oct 24 2002, 04:46 AM
VirtualdubMod Alpha tester
WarpEnterprises
Posted: Oct 24 2002, 06:44 PM
@IceCork: did you tell at the AviSynth forum (LINK) about your icon?
Looks quite good and there is still NO OTHER ONE yet !
IceCork
Posted: Oct 26 2002, 01:29 PM
I was going to post at those forums but the developers of AviSynth, having previously used an installer have reverted back to using .reg files (at the request of some users) to install AviSynth. Anyone however can add the icon themselves with Resource Hacker provided you unpack AviSynth with UPX first. You can then compile the script and run the installer. The icon will then be visible with ".avs" files. I've added seperate scripts for VDub & AviSynth so Avery, the AviSynth developers or anyone can use them if they want to. The NSIS install scripts require v.2.0b and can be found here :
AviSynth
VirtualDub
The icons are here :
AviSynth
VirtualDub
You'll have to rename the files from ".jpg" to ".zip" (Free web space provider problems).
Newer versions of Nullsoft's v.2.0 installer may break the scripts so I'll continue to update them as the installer changes. If you're not familiar with NSIS, v2.0 currently downloads as a zip file. After extracting the zip run "!InstallNSIS.bat" and follow the installer prompts. If you have any problems or questions about the scripts just post them in this forum. Below is a pic of the VDub installer.
muf
Posted: Oct 26 2002, 09:35 PM
MCF team member
QUOTE (IceCork @ Sep 20 2002, 09:23 AM)
I'd sent Avery an icon sometime ago also. Guess he didn't like mine either.
Below is a pic of it 32*32 16 colours.
Nice ripoff from the ASF icon biggrin.gif.
IceCork
Posted: Nov 3 2002, 01:56 PM
Congratulations Spire, cool icon. Check it out in the pic a couple of posts back.
WarpEnterprises
Posted: Nov 19 2002, 03:17 PM
Can anybody help me getting those AviSynth Icons?
I get an error when trying to download...
WarpEnterprises
Posted: Nov 26 2002, 12:26 PM
Thanks!
quote sh0dan:
Originally posted by WarpEnterprises
Would this be possible to integrate?
I integreated it into the installer, so that it will be used instead of the default NSIS one.
muf
Posted: Dec 1 2002, 05:53 PM
MCF team member
ChristianHJW
Posted: Dec 2 2002, 10:30 PM
lol .. now we have more icons than programs smile.gif !
muf
Posted: Dec 5 2002, 04:16 PM
MCF team member
Here's how it looks "in action":
Weird it's mirrored on the spinning cube though.
Posted: Dec 5 2002, 11:05 PM
In all the time I've had that about dialog, you're the first one to notice that I have the texture coordinates (UVs) swapped on the cube. It'll be fixed in the next revision. tongue.gif
25 replies since Sep 12 2002, 02:08 AM Track this topic | Email this topic | Print this topic
Pages: (2) 1 [2]
