S-video Capture Problems Filter
Quilty
Posted: Jun 18 2003, 11:12 AM
Here you can see the problem .... does anyone have a filter to correct this occurance? It seems to be only on thin lines of very saturated colours. The "staircase" pattern alternates from frame to frame (as I have simulated in the GIF). This has been through a Kramer Comp to S-video convertor, so the rest of it looks much better than the composite original, save for this error. I have tried the 2d comb filter, and Guava comb filter, and whilst Guava cleans it to a great extent, it mucks up the rest of the image.
There is a reward for the person who fixes it!!
Cheers,
Quilty
tereza
Posted: Jun 18 2003, 02:07 PM
have u tried some deinterlace filters? Tom
Quilty
Posted: Jun 18 2003, 02:15 PM
Sorry .. should have pointed out these are progressive frames Inverse Telecinied back to 23.976fps in After Effects. Thanks for your response, but I am not sure that would work sad.gif
Q.
Posted: Jun 19 2003, 02:50 AM
Those are chroma crosstalk artifacts. NTSC/PAL use quadrature encoding to encode the two color axes into a single modulated signal; as it turns out, the bandwidth allotment for one of the axes is asymmetrical on the reddish-orange side. It looks like your S-Video converter uses a symmetrical chroma separation filter, resulting in saturated reds bleeding into luma. This isn't uncommon, particularly with computer-generated output (Amiga 1000, anyone?).
One way to combat this problem would be an adaptive low-pass luma filter that's keyed to the reddish-orange chroma region. Unfortunately, I don't know offhand of a direct way to do this. Any Avisynth wizards have suggestions?
Also, why are you using a converter? Converting to S-Video isn't going to gain you anything over capturing composite directly unless the external converter you're using has a better chroma separator, and that doesn't really seem to be the case....
3 replies since Jun 18 2003, 11:12 AM Track this topic | Email this topic | Print this topic
