Need A Special Field Swap Filter Made
s00pcan
Posted: Jun 17 2003, 10:39 PM
I hope this would be easy for someone here to make for me. When I captured video at full resolution from my playstation 2 then tried do slo-mo by de-interlacing I noticed that every fourth field is in the wrong spot. It's like playing the field backwards. So what I need is a filter that swaps the field dominance every third frame.
Posted: Jun 18 2003, 12:23 AM
QUOTE (s00pcan @ Jun 17 2003, 06:39 PM)
I would try Avisynth with the following script:
src = AVISource("drive:\path\filename.avi")
clip1 = SelectEvery(src, 3, 0)
clip2 = SelectEvery(src, 3, 1)
clip3 = SelectEvery(src, 3, 2).SwapFields()
Interleave(clip1, clip2, clip3)
s00pcan
Posted: Jun 18 2003, 02:20 AM
Wait. I need it to swap fields on every even numbered frame. It sounds simple..
Posted: Jun 18 2003, 02:44 AM
QUOTE (s00pcan @ Jun 17 2003, 10:20 PM)
how about separating the fields first then swapping every fourth/fifth frame?
SeparateFields()
SelectEvery(5, 0,1,2,4,3)
Weave()
s00pcan
Posted: Jun 18 2003, 02:57 AM
scr = AVISource("clip.avi")
SelectOdd(scr).SwapFields()
separatefields
didn't work, but should have. I'll try your new code.
Posted: Jun 18 2003, 03:21 AM
clip1 = SelectEven(src).SwapFields()
clip2 = SelectOdd(src)
Interleave(clip1, clip2)
s00pcan
Posted: Jun 18 2003, 11:04 AM
Gah! That code makes complete sense but doesn't look any different than just separatefields by itself!
http://www.skateflint.com/slomo.avi
Here's an compressed clip so you can see what I mean. Using separatefields you can clearly see that problem. This should help.
Posted: Jun 18 2003, 03:24 PM
I see. At times the motion appears backward, but it looks random to me. If there's no pattern to it then it's going to be really difficult to fix.
One question: Did you capture this at 29.97 fps originally? If not, then that could be the cause of the screwed-up field order.
s00pcan
Posted: Jun 18 2003, 04:55 PM
Well I captured it at 30fps.. I tried 29.97 and it still does it.
Posted: Jun 18 2003, 06:01 PM
Looking at your sample again, there is a pattern which kicks in after the 11th field. At that point (like you said), every fourth field is backwards. Try this:
SeparateFields()
SelectEvery(4, 0,1,3,2)
And ring all the changes for "SelectEvery" until it comes out right. If the pattern really is every fourth field, then there are 4 possibilities:
SelectEvery(4, 1,0,2,3)
SelectEvery(4, 0,2,1,3)
SelectEvery(4, 3,1,2,0)
s00pcan
Posted: Jun 19 2003, 02:16 PM
this works very well but then starts to mess up. I'm guessing there was a dropped frame or something that threw it off. I'll try capturing another clip.
http://www.skateflint.com/goodslomo.mpg
the filename speaks for itself.. thanks!
10 replies since Jun 17 2003, 10:39 PM Track this topic | Email this topic | Print this topic
