| basxcore |
| Posted: Mar 26 2003, 09:20 AM |
I want to start a frame server for adding Subtitles to my AVI. I make use of the TextSub 2.23 filter. I add a .SRT for this movie. But when previewing i see the text in the picture window.
Is it posible to lower the subtiteling down into the black "unused space". I know this can be done with .IDX files.
Thanks for any help!
Greetzz, Bas. |
| Borgster |
Posted: Mar 28 2003, 07:17 AM |
Hi Bas,
Yes it's is quite easy to do that.
1 - load your Avi 2 - goto > Video > Filters > Add > Resize filter
If your Avi is for example 576 x 352 and you want to make SVCD 480x480 you resize to 576 x 352 (precise bicubic) and checkmark the expand letterbox and fill in the new 576 x 576.
3 - if the black bar is too small for two lines of text you can use (Shiftwrap) 4 - Add the texsub filter with the subs.
That's it!!
Good luck |
