| krt47 |
| Posted: Feb 21 2014, 01:06 AM |
hi there, it's been awhile. i was wounder if any budy can help me to create a script from rgb32 to YCBCR 4:4:4 Subchroma. can some please help me create one for vshader filter?
thanks |
| raffriff42 |
| Posted: Feb 21 2014, 02:24 PM |
| CODE | // RGB to YCbCr sampler src;
float4 PS(float2 uv: TEXCOORD0) : COLOR0 { float4 px; // Note that we are using full-range equations here, not the standard encoding // with headroom. // // Y = 0.299 R + 0.587 G + 0.114 B // Cb = - 0.1687 R - 0.3313 G + 0.5 B + 128 // Cr = 0.5 R - 0.4187 G - 0.0813 B + 128
float3x3 mx=float3x3( float3(0.5, 0.299, -0.1687), float3(-0.4187, 0.587, -0.3313), float3(-0.0813, 0.114, 0.5) );
px = tex2D(src, uv);
float3 cyc = mul(px.rgb, mx) + float3(128.0/255.0, 0, 128.0/255.0);
return float4(cyc, px.a); }
technique { pass { PixelShader = compile ps_3_0 PS(); } }
| Sources https://www.google.com/search?q=directx+sha...shader+fx+ycbcr http://www.virtualdub.org/blog/pivot/entry.php?id=154 http://www.virtualdub.org/downloads/vdshad...der-1.0-src.zip |
| krt47 |
| Posted: Feb 21 2014, 08:34 PM |
it's change the color to ycbcr instead of 4:4:4 see
before http://imageshack.com/a/img21/9836/vsq5.png after http://imageshack.com/a/img208/7448/r979.png
how come the the script seems to change the black and white colors? is suppose to change seem the colors that are black and white to purple? how com it dosen't change other colors?
at least far as i know it's suppose not change the black and white colors. the other colors suppose be more vivid.
oh and p.s. i asked for rgba32 to ycbcr 4:4:4 color format instead of rgb to ycbcr. sorry i made a mistake about what i said up above. |
| raffriff42 |
| Posted: Feb 22 2014, 02:43 AM |
It looks like YCbCr is being displayed *as if* it was GBR. You need to flag your output somehow as YCbCr. Examine the ConvertFormat filter source code (src\VDFilters\source\VFConvertFormat.cpp), and search Vdub source for kPixFormat_*. Sorry I'm not more help here.
EDIT - avisynth script confirming my guess (you have a 4-pixel shift problem as well, hopefully someone more knowledgeable can help you with that) | CODE | Before=ImageSource("vsq5.png") After=ImageSource("r979.png")
## http://avisynth.nl/index.php/Swap AfterYUV=YToUV( \ After.ShowBlue .ConvertToY8, /* U (Cb) channel */ \ After.ShowRed .ConvertToY8, /* V (Cr) channel */ \ After.ShowGreen .ConvertToY8) /* Y channel */
## compare clips - for use in frame step mode only! return Interleave( \ Before.Subtitle("Before"), \ Overlay(Before, AfterYUV, x=-4).Subtitle("AfterYUV"))
This post has been edited by raffriff42 on Feb 22 2014, 03:58 AM |
| krt47 |
| Posted: Feb 22 2014, 02:47 PM |
| QUOTE (raffriff42 @ Feb 22 2014, 02:43 AM) | It looks like YCbCr is being displayed *as if* it was GBR. You need to flag your output somehow as YCbCr. Examine the ConvertFormat filter source code (src\VDFilters\source\VFConvertFormat.cpp), and search Vdub source for kPixFormat_*. Sorry I'm not more help here.
| | thank for your feedback. i sure hope some can help me with this. anyone else know how i can do this with vshader? |
| Posted: Feb 23 2014, 09:25 PM |
If you're using VDShader, the 4-pixel shift problem was a bug with earlier versions in the SSE2 JIT -- check that you are using version 1.4.
Also, if all you want to do is change the pixel format and not actually the colors in the image, the Convert Format filter will convert to 4:4:4. However...
| QUOTE | the other colors suppose be more vivid
...this wouldn't be expected. Converting between encoding formats isn't supposed to change saturation/contrast/brightness. |
| Altaf |
| Posted: Feb 24 2014, 04:23 PM |
I don't know as to make 4:4:4. I read that the size of the file decreases at the same quality. |
| krt47 |
| Posted: Feb 24 2014, 08:45 PM |
| QUOTE (phaeron @ Feb 23 2014, 09:25 PM) | If you're using VDShader, the 4-pixel shift problem was a bug with earlier versions in the SSE2 JIT -- check that you are using version 1.4.
...this wouldn't be expected. Converting between encoding formats isn't supposed to change saturation/contrast/brightness. | ok phaeron the 4-pixel shift was fixed in what now? please specify? i don't see a filter or the time line in the log where the 4-pixel shift was fixed. |
