| rmanal |
| Posted: Dec 29 2013, 10:04 AM |
Hello,
I have an ssue with a MKV file containing subtitle. I explain: - If I use the natural haali splitter, and so open the file with direct show plugin, then I got the video and audio, but not the subtitle - I have so use the MKV plugin of FCChandler, but in this case VD is not able to render the audio part (tag: 2000)
So I'm a little bit blocked: can anyone help me? The file is more than 1Go so it is very difficult to share it.
Additional question: where is FCChandler? Has he left the VD story?
Thank you Rmanal |
| Posted: Dec 29 2013, 12:39 PM |
You need the ac3 acm codec for code 2000 There's a link to ffcHandlers stuff in my sig you'll find that there (I put all of fccHandlers stuff on SourceForge as fccHandler just stopped appearing one day)
There are other useful input plugins at http://forums.virtualdub.org/index.php?act...=ST&f=7&t=19488
The FFMpeg plugin can load most files without any external codecs -not sure what that does with subs, probably nothing though
The DirectShow plugin uses your systems installed DirectShow Filters, so you'd need a DirectShow subtitle filter and splitter that supports them DirectVobSub and FFDShow are such filters, I'm not sure if Haali splits them (it may be in it's options) but LAVSplitter does
| rmanal |
| Posted: Dec 29 2013, 12:47 PM |
Why iyt is working with FDDSHOW plugin but not with FCChandler MKV plugin???? |
| Posted: Dec 29 2013, 12:49 PM |
FFDShow has two settings DirectShow and VFW MKV plugin uses VFW, so check the FFDShow VFW settings for subtitles
| rmanal |
| Posted: Dec 29 2013, 01:06 PM |
Sorry for being stupid and thank you for your answer, but: - I have put the FFMPEG plugin, but how to use it when I open a file (I don't see the choice FFMPEG)? - I have already the AC3 plugin: isn't it sufficient?
I will check FFDSHOW configuration, thank you again |
| Posted: Dec 29 2013, 01:12 PM |
Not the ac3 plugin, the ac3 acm codec :-) They're two separate things, the first allows you to use ac3 as separate audio souce
FFMpeg plugin is selected from the 'files of type' on the open video dialog After the plugin is put in the plugins32 folder, you have to restart virtualdub as it only loads them when it starts
| rmanal |
| Posted: Dec 29 2013, 02:08 PM |
OK, i'm progressing I have now installed an AC3 filter and it is functionning with the MKV plugin. But I still don't see the subtitle: how to make it appearing in the video?
For FFMPEG, which is the "files of type" to use, because I have only one MKV which is the matroska one?
Thank you again for your support. |
| Posted: Dec 29 2013, 02:42 PM |
To pick a plugin, on the open a video dialog, click the video you want, and then look towards the bottom of the dialog There's a combobox there called 'files of type' setting, pick the input plugin you want and then click ok
So I've just had a play with the mkv plugin and ffdshwo - looks like ffdshow vfw doesn't do subs, or if it does the mkv plugin ignores them So what I did was turn on subtitles for ffdshows directshow plugin and use the directshow plugin ...and that didn't play embedded subs in the file.... even with the play embedded subs options on
Soooo, I extracted the subs to a file with mkvtoolnix, named it the same as the video and then tried again with the directshow plugin That worked fine
btw ffmpeg plugin doesn't do subs after a quick check
| rmanal |
| Posted: Dec 29 2013, 03:47 PM |
Pfff Effectively it seems that the haali splitter sub output is not used by VD, and Haali does not incrust by itself the sub in the video stream.
So a good improvement for the matroska plugin ;-)
What is the name of the FFMPEG file of type??? I don't see it I think, or just not recognize it.
I will test mkvtoolnix |
| rmanal |
| Posted: Dec 29 2013, 03:57 PM |
argh, how do you use mkvtoolnix to extract just the sub: it seems to merge file? |
| Posted: Dec 29 2013, 04:14 PM |
If it's not here
[CODE] 1) the plugin could be in the wrong place 2) you didn't put the ffdlls folder inside the plugins folder 3) you've mixed up the 32/64 bit plugin and virtualdub version (they have to be the same)
GUI for mkvextract http://sourceforge.net/projects/mkvextractgui-2/
| QUOTE | | So a good improvement for the matroska plugin ;-) |
Nobody's working on it
| rmanal |
| Posted: Dec 30 2013, 09:01 AM |
For FFMPEG, I can not see it?? But ok it is not a problem as it will not help me.
For MKV ok there is an additional software. Thank you. It seems to work ;-)
For the future (;-)) MKV, I can wait (of course i'm joking if it is not obvious. even if I would like, I have no skill for programmation).
Thank you for all your support |
| Posted: Dec 30 2013, 09:18 AM |
It's a shame about fccHandlers plugins
TBH I just tend to use the FFMPeg and DirectShow ones now though
