| diablo23q |
| Posted: Feb 22 2012, 02:24 PM |
Hello, everyone! I'm proud to present new MSU VirtualDub filter  Here it is - http://compression.ru/video/deinterlacer/index_en.html Report bugs to deinterlacer _at_ graphics.cs.msu.ru |
| jpsdr |
| Posted: Feb 23 2012, 08:37 AM |
Only 32bits version ???
Apparently your filter seems to work with YV12 but not YV16 (converted to YV24). Am i right ?
You're not totaly correctly using the last API, because the [C] is still appearing even apparently when there is no conversion format made (with last 1.10.2-test3 version). I've had the same problem with my filters while updating to last API, i don't remember exactly what corrected it... I think it's updating to the last vdvideofilt.h, wich set VIRTUALDUB_FILTERDEF_VERSION to 16 wich corrected the problem.
Well, updating all files from the last SDK-1.2 should solve this issue.
I think a Preview could be nice, it would allow to see instantly effect of checked boxes. |
| evropej |
| Posted: Feb 24 2012, 02:08 PM |
it works but not that many options |
| Gromozeka |
| Posted: Feb 25 2012, 04:49 PM |
diablo23q
Thank you very much Спасибо земляк за фильтр |
| evropej |
| Posted: Jan 23 2014, 10:06 PM |
Is the main page updated with all the new filters? |
