5.1 Aac To 5.1 Ac-3 Audio Conversion Not Working
Dstruct
  Posted: Nov 8 2011, 07:24 AM
VirtualDub 1.10.1-test15
With this file
Format                         : Matroska
Format version                 : Version 1
File size                      : 1 003 MiB
Duration                       : 2h 5mn
Overall bit rate               : 1 113 Kbps
Writing application            : HandBrake 0.9.3
Video
Format                         : AVC
Format/Info                    : Advanced Video Codec
Format profile                 : High@L3.0
Format settings, CABAC         : Yes
Format settings, ReFrames      : 3 frames
Codec ID                       : V_MPEG4/ISO/AVC
Duration                       : 2h 5mn
Nominal bit rate               : 655 Kbps
Width                          : 720 pixels
Height                         : 422 pixels
Display aspect ratio           : 2.40:1
Frame rate                     : 25.000 fps
Color space                    : YUV
Chroma subsampling             : 4:2:0
Bit depth                      : 8 bits
Scan type                      : Progressive
Bits/(Pixel*Frame)             : 0.086
Writing library                : x264 core 65
Encoding settings              : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=9 / psy_rd=1.0:1.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-4 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=6 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=655 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
Language                       : English
Color primaries                : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Transfer characteristics       : BT.709-5, BT.1361
Matrix coefficients            : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Audio #1
Format                         : AAC
Format/Info                    : Advanced Audio Codec
Format profile                 : LC
Codec ID                       : A_AAC
Duration                       : 2h 5mn
Channel(s)                     : 6 channels
Channel positions              : Front: L C R, Side: L R, LFE
Sampling rate                  : 48.0 KHz
Compression mode               : Lossy
Language                       : English
Audio #2
Format                         : AAC
Format profile                 : LC
Codec ID                       : A_AAC
Duration                       : 2h 5mn
Language                       : German
Menu
00:00:00.000                   : Chapter 1
00:03:17.813                   : Chapter 2
00:06:19.973                   : Chapter 3
00:09:19.133                   : Chapter 4
00:11:29.413                   : Chapter 5
00:16:06.613                   : Chapter 6
00:20:40.133                   : Chapter 7
00:24:07.373                   : Chapter 8
00:27:40.773                   : Chapter 9
00:31:05.983                   : Chapter 10
00:33:55.370                   : Chapter 11
00:37:06.130                   : Chapter 12
00:42:33.970                   : Chapter 13
00:44:39.410                   : Chapter 14
00:46:58.010                   : Chapter 15
00:51:20.320                   : Chapter 16
00:54:13.600                   : Chapter 17
00:56:36.520                   : Chapter 18
00:58:38.680                   : Chapter 19
01:02:36.570                   : Chapter 20
01:05:00.650                   : Chapter 21
01:09:35.730                   : Chapter 22
01:14:38.690                   : Chapter 23
01:17:44.288                   : Chapter 24
01:21:36.797                   : Chapter 25
01:26:04.997                   : Chapter 26
01:27:43.317                   : Chapter 27
01:33:26.357                   : Chapter 28
01:36:56.877                   : Chapter 29
01:40:04.555                   : Chapter 30
01:42:38.113                   : Chapter 31
01:45:47.793                   : Chapter 32
01:48:19.550                   : Chapter 33
01:51:50.900                   : Chapter 34
01:53:58.020                   : Chapter 35
01:57:27.060                   : Chapter 36
02:00:33.500                   : Chapter 37
02:03:30.780                   : Chapter 38"
I'm getting a "Error initializing audio stream compression: No installed audio codec could compress the source audio to the desired format. Check that the sampling rate and number of channels in the source is compatible with the selected audio format." error message in VirtualDub when trying to save this file with 5.1 AC-3 320kbps compression.
fccHandler AAC ACM Codec 1.8
fccHandler AC-3 ACM Codec 1.9
fccHandler Matroska Plugin 3.0
Shouldn't it work (6ch AAC conversion to 6ch AC-3)?
0 replies since Nov 8 2011, 07:24 AM Track this topic | Email this topic | Print this topic
