| loin2kolpotoru |
| Posted: Apr 23 2011, 04:51 PM |
I Use DShowInputDriver and most of the files opens with it but i have a sujjestion - Can Someone Please make a DShowInputDriver which will support DirectStream Copy option that will increase DShowInputDriver's Usabilty imensly.
Another thing is that the DShowInputDriver distribution should include a Readme file which will have the release date & a short descripton about how to use it this will be very useful for new users. |
| Posted: Apr 24 2011, 09:28 PM |
This is not possible from a plugin -- if you're using DShowInputDriver you're probably using a format like MPEG-4 or H.264, which requires different handling than the core support for direct stream copy. |
