Mpeg-2 Input Plugin And Mod/moi Files
ale5000
Posted: Feb 26 2011, 12:11 PM
Could you add .mod extension to the MPEG-2 plugin?
A .mod file is an mpeg-2 file, just the aspect ratio information are stored externally in a .moi file (there are also Amiga Music Module File with mod extension, these ones shouldn't be accepted)
More info are here: http://www.masternewmedia.org/how_to_conve...video_files_to/
An example file is here: http://samples.mplayerhq.hu/camera-dvr/Exa...C_MOD_VIDEO.MOD
I wasn't able to find online a matching couple of mod/moi but I have found some .moi files: http://www.megaupload.com/?d=ZH4HXA47
New VirtualDub forum
v0lt
Posted: Feb 26 2011, 01:29 PM
Such a request has already been. It was rejected. Done correctly.
ale5000
Posted: Feb 26 2011, 02:13 PM
Could you please point me to the thread of the request?
Posted: Feb 26 2011, 05:36 PM
I looked at the file and it seems to be a normal MPEG movie with a wrong extension. To make it right (IMHO) you should give it a proper .mpg extension. The .mod extension was already claimed a long time ago and I do not intend to add it to the plugin, sorry. You might as well have asked me to add the .txt extension. rolleyes.gif
And no v0lt, I have not been asked this before.
ale5000
Posted: Feb 26 2011, 08:09 PM
But the info found over the internet say that they ARE normal MPEG-2 movie.
What do you mean?
Posted: Feb 26 2011, 08:39 PM
QUOTE (ale5000 @ Feb 26 2011, 04:09 PM)
But the info found over the internet say that thery ARE normal MPEG-2 movie.
Yes indeed. But real MPEG movies are expected to carry an .mpg extension. These files are misnamed, and in my opinion that is a bad practice which I do not agree with and do not wish to condone.
The .mod extension is for MOD files, and has been since 1987 (!) according to this:
http://en.wikipedia.org/wiki/MOD_(file_format)
I actually have quite a few MOD files from the old days and I would not expect them to show up in VirtualDub's list of supported formats. Although I respect your request, I feel that adding the .mod extension might spread confusion and I don't want to do that. Sorry.
ale5000
Posted: Feb 26 2011, 09:23 PM
Well the extension itself isn't a big problem, but it still would be nice if there is a filename.mpg (renamed from .mod, or with .mod extension but with mpeg-2 plugin forced using drop down menu) and filename.moi in the same folder and with the same name that it will read info like aspect ratio from the .moi file.
QUOTE (http://www.masternewmedia.org/how_to_convert_mod_video_files_to/)
video standard used (PAL or NTSC), the aspect ratio used, and the interlacing.
The problem with these tags stems from the fact that they are being stored in associated small text files with the extension MOI.
Once you separate the MOD file from its companion MOI file, the video software you use to open the video file doesn't know anymore what aspect ratio and video file format is being used and tries to guess automatically.
i4004
Posted: Feb 27 2011, 03:25 AM
how hard can it be to guess AR if video is in wrong "shape"?
my signature:
Posted: Feb 27 2011, 03:48 AM
...they are being stored in associated small text files with the extension MOI.
The .moi files you posted are definitely not text files. And to be frank I really have no interest in supporting this perversion of the MPEG standard. I'm sorry that it is an inconvenience to you, but the blame is on Canon as far as I'm concerned.
ale5000
Posted: Feb 27 2011, 04:13 AM
Don't worry, your continuous work on input plugins is really appreciated biggrin.gif
v0lt
Posted: Feb 27 2011, 04:49 AM
file can always be renamed. not need to do absolutely support all the extensions, especially if the cause misunderstanding.
. mod is tracker music, perhaps a module of the program, but not MPEG
Posted: Feb 27 2011, 06:23 AM
Also be aware that I treat the MPEG aspect ratio information as purely informative. It isn't utilized at all by the plugin. You will receive the same raw video data no matter what the aspect ratio is.
11 replies since Feb 26 2011, 12:11 PM Track this topic | Email this topic | Print this topic
