Mp4 And Wmv Files In Virtual Dub, Missing Codec?
brevardo
Posted: Jan 13 2011, 02:21 AM
I'm having a very hard time as I have the most recent version of Virtual Dub and I installed the WMV and MP4 plugins but I still can't get them to work? When I try to load a WMV file in virtual Dub it goes thru the motions and loads just like it would on an AVI file but it says "missing codec" I've tried to follow the instructions of others that I've Googled and loaded FFDShow and Direct Show and probably three other fixes and nothing works? When I try to load an MP4 I get nothing but a black screen? There must be an easier, updated way to load something and easily enable it. I tired to follow the instructions to enable the VFW configuration in FFDShow and it's not user-friendly. Please advise?
ale5000
Posted: Jan 13 2011, 03:21 AM
1) Make sure you have ffdshow-tryout ( http://sourceforge.net/projects/ffdshow-tryout/files/ ) and not ffdshow.
2) If you use 32-bit VirtualDub you should have 32-bit ffdshow-tryout instead if you use 64-bit VirtualDub you should have 64-bit ffdshow-tryout.
3) Go in the VFW configuration (yellow icon, many user incorrectly use the red one) of ffdshow-tryout => Decoder => Codecs => then set WMV1/7, WMV2/8, WMV3/9 to wmv9.
Like this: user posted image
This should make the wmv files working.
For the mp4 open them with MediaInfo ( http://sourceforge.net/projects/mediainfo/ ) and tell what video/audio format it is.
New VirtualDub forum
Exlua
Posted: Jan 31 2011, 03:22 PM
Thank you for this Tip ! The Video WMV Part Works but the Audio Part not sad.gif
0x0161 is a WMA Codec i have WMp11 where is the Problem ?
Suggestions ?
ale5000
Posted: Jan 31 2011, 05:16 PM
QUOTE (Exlua @ Jan 31 2011, 03:22 PM)
Suggestions ?
A normal codec (directshow) isn't usefull in VirtualDub, for the audio in VirtualDub you need an ACM codec.
You can find it here: http://forums.virtualdub.org/index.php?act...=ST&f=7&t=19488
DarrellS
Posted: Jan 31 2011, 06:39 PM
You need either the hacked DivX 3.11 codec
http://www.videohelp.com/download/divx_3.11alpha.zip
or just the audio codec part of it
http://www.videohelp.com/download/DivXAudi...ressor_4.02.zip
For WMA Professional, you'll have to convert to something usable first
ale5000
Posted: Jan 31 2011, 06:58 PM
@DarrellS: The one specified by me contain the "Windows Media Audio" ACM codec while the one you linked is the hacked "DivX;-) Audio" codec (the format is the same).
WMA Professional is 0x0162 so this isn't the case.
anidealworld
Posted: Feb 26 2011, 08:40 PM
Thanks this post has been hugely helpful for me. If I DO have a WMA Professional (0x0162) file then how do I get the audio to work? I think that's what's causing my file to not render or play.
Do have to convert it out of WMA Pro? I'm trying to do this all without any conversion... thanks!
ale5000
Posted: Feb 26 2011, 09:53 PM
@anidealworld: What are you trying to do?
If you don't want the conversion just use Direct Stream Copy.
anidealworld
  Posted: Mar 2 2011, 11:03 PM
Basically I get this error when I try to load a file:
VirtualDub Error
No audio decompressor could be found to decompress the source audio format.
(source format tag: 0162)
I made the movie in Windows Live Movie Maker in Win 7 and was using VirtualDub for post processing and to convert back to mp4, but it just can't seem to find the audio decoder.
ale5000
Posted: Mar 2 2011, 11:18 PM
If you use "Audio => Direct Stream Copy" VirtualDub will copy the WMA Professional audio without any conversion in the .avi container (the preview still won't work but the File => Save as AVI... will work).
If you also need to convert the audio you have to extract it and convert with another program (which I don't know).
9 replies since Jan 13 2011, 02:21 AM Track this topic | Email this topic | Print this topic
