Fairly Quick Filter Multiadjust, Brightness, contrast, saturation, hue...
Posted: Jul 14 2010, 03:21 AM
Here's my first finished filter+ full sourcecode (142k)
V0.2.3
[29-12-2013]
https://sourceforge.net/projects/multiadjust/
MultiAdjust V0.2.3
Lookup based adjustment of
Brightness
Contrast
Saturation
Hue
There are 5 types of brightness adjustment
Normal
Low level
Low level + boost
Flatten
Flatten + boost
Use YUV 16-239 or 0-255 levels
Video formats accepted
Y8
YUV422_UYVY (UYVY)
YUV422_YUYV (YUY2)
YUV444_Planar (YV24)
YUV422_Planar (YV16)
YUV420_Planar (YV12)
YUV411_Planar
YUV410_Planar (YVU9)
Routines use either SSE, X86
(SSE won't be used unless the cpu supports it)
There isn't actually much difference in speed between SSE and X86 though
Full source code is included, feel free to use as you like
History
V0.2.3
Added
Show out of spec input levels in preview window
Fix small error in scaling
V0.2.1
Added
Colourspace 601<>709 conversion
V0.2.0
Added
Combined contrast/brighness checkbox
Adjust brighness-before-contrast/contrast-before-brightness checkbox
Minor bugfixes
V0.1.9
Checkbox for saturation only to affect red's
V0.1.8
Added
Experimental Hilight reduction
V0.1.7
Bugfix
Silly mistake(after moving preview options around) saved jobs had the filter disabled - my bad
V0.1.6
Added
Icons for reset buttons
Help button
About button
Moved some of the buttons about
V0.1.5
Remove preview button and open preview window automatically
V0.1.4
Added for JohnI
Preview window - disable effects
Preview window - only show effect on half of image
Individual slider reset buttons
V0.1.3
Bugfix - for YUV values <16
V0.1.2
Modified configuration dialog
Added YUV levels option 16-239 or 0-255
V0.1.1
Code cleanup
Removed sse/x86/c++ switch that was there for testing
V0.1
Initial release
Karl
dloneranger67@gmail.com
jpsdr
Posted: Jul 14 2010, 07:06 AM
Euh... constrat should ajust only Y.
What's doing the same thing that constrat on U/V is saturation.
Posted: Jul 14 2010, 07:31 AM
http://msdn.microsoft.com/en-us/library/ff...28VS.85%29.aspx
Just following the formulas at MSDN
I've made it optional now though
It doesn't really make much difference one way or the other on an adjustment filter though
The user moves the sliders around to get a picture they like
jpsdr
Posted: Jul 15 2010, 07:45 AM
I said this with TV adjustment in mind : Adjusting contrast on TV act only on Y (at least, on the TV i've seen until now).
Posted: Jul 15 2010, 09:17 AM
There seem to be 2 views on it spread around the net :-)
While looking for formulas I found lots, but settled on the msdn one , for the look it gave
Just altering Y seems to wash out the saturation, so I guess it makes sense
But... it's an adjustment filter and if it doesn't look right, you just move some sliders a bit more ;-)
TBH this was just 'my first attempt at assembler' since my old atari, and my first plugin filter as well
I was just glad it worked, but the speed is quite pleasing as it's the kind of adjustment I make all the time
Posted: Jul 16 2010, 02:11 AM
Updated to V0.11
(Code cleanup + removal of test code)
rjisinspired
Posted: Jul 16 2010, 07:06 AM
Thanks for your work with your new filter. One question though: When saturation and contrast is linked what happens?
I first expected that either the sliders for saturation and contrast would move in relation to one other when that option was checked or that moving say contrast will keep the color intact?
I like the brightness options. The brightness options work the opposite if brightness is lessened which is pretty neat.
Update:
Ahhhhh - I see what the linking of contrast and color does. I was playing with the saturation slider but didn't get it until I worked with the contrast slider. That is cool.
Posted: Jul 16 2010, 09:46 AM
Just explaining in case anyone else wants to know
Linking the saturation and contrast means that when you increase the contrast, the saturation is boosted as well
The four brightness methods:
Normal, Boost (gives more 'pop' to the image) and 2 that affect darker areas more (it's fairly subtle though)
I did a speed test on another thread, but I'll repost the results here
Testing with 1 hour 30 minutes clip, full processing, uncompressed output, no audio, then run analysis to check speeds
No filters
4 mins 20 seconds (to get a baseline)
Built in Brightness/contrast filter
7 mins 53 seconds
Built in hsv filter
25 mins 40 seconds
This brightness/contrast/hue/saturation filter
5 mins 5 seconds
Extra time added by filters
3 mins 33 seconds
Built in hsv filter
21 mins 20 seconds
MultiAdjust
45 seconds
Posted: Jul 18 2010, 04:43 PM
Updated to v0.1.2
Added YUV levels selection 0-239 or 0-255
Changed number of brightness adjustment methods
Posted: Jul 30 2010, 08:26 AM
Bugfix for levels <16 (blacker-than-black)
John I.
Posted: Jul 31 2010, 06:10 AM
dloneranger,
Having all these controls in one filter and performing at this speed is really wonderful.
Are you considering adding gamma ?
Also, if you don't mind some suggestions that maybe you would like to consider:
- An additional reset button for each control, instead of resetting them all.
- An 'Enable filter' button to to allow comparing the filtered and unfiltered states in the filter preview instead of having to go out of filters and do that in virtualdub's two windows. In cases of subtle changes, it is hard to tell the difference between the two windows. (I wish all filters have this button. it will save so many going in and out of the filters module.)
This filter is definitely becoming one of the most used filters for me.
Keep the good work.
Posted: Jul 31 2010, 11:52 AM
Interesting suggestions
When I fully wake up I'll take a look
Yeah, I'll add that and probably a 'only affect the left half of the image' option for comparisons
Reset button for each control
Not a problem
Gamma
I haven't found a formula that doesn't look awful yet
The best I've found looked worse than altering the brightness/contrast manually
But I do keep looking when I have spare time
(Most of this is a 3am 'I'm bored' project)
The brightness modes do something similar though
Each one affects different brightness ranges more than others
Posted: Jul 31 2010, 01:37 PM
Updated to V0.14
Added for JohnI
John I.
Posted: Jul 31 2010, 06:36 PM
And you have also added an extra bonus 'Full/Half preview'.
I have one comment. I see that maybe because you don't want to clutter the screen, you have included all the preview options in one drop list.
Is it possible to have this as two tick boxes, one for enable, and the other for full/half preview ? (The comparison will be quicker at one mouse click.)
Posted: Jul 31 2010, 07:04 PM
Yeah, it's getting large
What I do is just put the mouse cursor over comboboxes and roll the mousewheel
If that's not acceptable I'll look at 2 checkboxes
39 replies since Jul 14 2010, 03:21 AM Track this topic | Email this topic | Print this topic
Pages: (3) [1] 2 3
