| dizzy23nc |
| Posted: Jan 20 2003, 03:01 AM |
what filter should I use when i have blocks during movement? I'm trying deinterlace map now, but no luck yet. what filter is best and what settings for it are most commonly used?
thanks in advance |
| ChristianHJW |
| Posted: Jan 20 2003, 09:20 AM |
This can not be removed with a filter, you are obviously setting a very low bitrate in combination with a very high resolution, so the compressed video stream is blocky, especially in motion scenes where it needs more bits.
You can remove some of these effects with a good postprcessing filter on playback, but i recommend to either set a higher bitrate or to lower resolution ...
