Calling Filters, Bring up the Config from External Prog
jcsston
Posted: Jan 16 2003, 01:05 AM
Matroska Dev
Is it possible to bring up the config dialog for a filter from an external program?
If so what sub/function do you call?
I've tried the ConfigDlgProc but Visual Basic says 'Can't find DLL entry point'
my vb ph34r.gif code
Private Type FilterData
   show As Boolean
   smoothMotionMap As Boolean
   useMotionMap As Boolean
   deinterlaceThreshold As Integer
   lineDetect As Integer
   motionThreshold As Integer
   prevFrameLuma As Integer
   ixelbackUp As String
   pixelChanges As String
End Type
Private Declare Function ConfigDlgProc Lib "D:\Visual Basic Files\DeinterlaceMAP.vdf" (hdlg As Long, msg As Integer, wParam As FilterData, lParam As FilterData) As Boolean
'The C code def
'BOOL CALLBACK ConfigDlgProc(HWND hdlg, UINT msg, WPARAM wParam, LPARAM lParam)
Use the Matroska file format
Posted: Jan 16 2003, 01:53 AM
Interesting idea, but it can't be done.
Filter modules export two functions, "VirtualdubFilterModuleInit2" and "VirtualdubFilterModuleDeinit." Both of these functions receive pointers to other functions within VirtualDub itself. If you are not VirtualDub, you can't supply the filter with these pointers.
But even if you could supply some pointers for the filter to call, Visual Basic can't call the filter's exported functions anyway because they use the C calling convention (VB doesn't support this).
jcsston
Posted: Jan 16 2003, 02:05 AM
Matroska Dev
Thanks for the information
Maybe I could write an C dll that called the filter and then use the dll I wrote in VB wacko.gif
2 replies since Jan 16 2003, 01:05 AM Track this topic | Email this topic | Print this topic
