Vt Adjust, it goes up and up and up ...
error
Posted: Nov 25 2002, 02:14 PM
when I capture a videoclip with VD the VT-adjust counter goes up and up so that after ~10 minutes already I hear the sound ~1-2 seconds after I saw the picture... I'm using a 400Mhz-PC @~200MB RAM, WinTV Go, Terratec 128 PCI and I'm compressing the video by using the Huffyuv-Codec.
thx ia - error
ps.: Video format: 320x240 @ 24Bit; Sound: Maximum (44k/16/s); FPS: 30
minion
Posted: Nov 26 2002, 10:00 AM
Well this Usually happens, as the lag between your soud card and Capture card gets greater over time the VT adjust gets Greater and dropped frames attribute to the VT adjust also..You probably have a badly timed sound map for the sound card..In most cases if you have the Timeing setting on under the Capture menu then it should Dynamicly adjust the audio frequency and drop or add frames to Keep the correct time...
error
Posted: Nov 26 2002, 09:01 PM
QUOTE (minion @ Nov 26 2002, 11:00 AM)
This option is already active...
2 replies since Nov 25 2002, 02:14 PM Track this topic | Email this topic | Print this topic
<< Back to Capture
