Ok, A Question To You All...
The Zep Man
  Posted: Nov 19 2002, 07:36 PM
I have recorded some Sailor Moon episodes a little while ago...
Info about the recorded episodes:
Video
Codec: DivX
Format: RGB 24-bit
Resolution: 384 x 288
FPS: 25
Sound: PCM 44 khz, 16-bit, Stereo
Recorded from: Analog device, in fact it was recorded directly from a TV Channel
Now OK, here is the question:
I want some advise for which filters to use... the image is a bit dirty, probably because it was live from TV, and I want to make the lines in the
image a bit "sharper"...
Also, if I use a filter, I don't like side-effects when using it (fading of frames, fast movement of some pixels etc.)
So, if anybody knows a good list of filters to use, and off course their properties, post it plz wub.gif
-Zep
jcsston
Posted: Nov 19 2002, 07:50 PM
Matroska Dev
When I am cleaning up cartoons with heavy noise I use
Smart Smoother HiQuality 1.1 diam 7 thr 50 amount 200
and and then Dynamic Noise Reduction 2.1 at 18 or
the built-in Temporal Smoother at 4,
last I use the built-in Sharpen filter set to 10.
I use the settings solely for cartoons, if the noise is light I lower the amount of the Smart Smoother or take it off.
Use the Matroska file format
The Zep Man
Posted: Nov 19 2002, 08:30 PM
Thx for the fast reply, jcsston...
jcsston
Posted: Nov 19 2002, 10:40 PM
Matroska Dev
good luck
3 replies since Nov 19 2002, 07:36 PM Track this topic | Email this topic | Print this topic
<< Back to Capture
