Terrorhörnchen
This is what Avery told about it:
| QUOTE | | For the last time, yes, VirtualDub is compatible with Windows XP. It is, however, not compatible with DirectShow (Windows Driver Model) capture devices except when the Microsoft VFWWDM wrapper is installed, which does not let you capture integrated audio and is not available under XP. A solution is in the works but I can't tell you when it will be finished |
You could try other drivers: http://btwincap.sourceforge.net/ or the BtWinCap driver mode switcher written by koepi: http://www.roeder.goe.net/~koepi/ or maybe the last VDub Version is better ? Dont know it, but I think the problem is the missing timer function an sync algorithm in the "original"
