Only 16.6676 Frames, no matter what i try, always the same
HiRsch
Posted: Oct 6 2002, 09:02 PM
HI,
i got the problem that, no matter what i select, i only got around 16 frames. i can enter every framrate, i can enter every sampling frequ. i can use whatever codec i want, but i can't get over 16 frames, while my cpu usage is just around 2-3%.
using a p4 2GHz, Geforce 4 Mx, win xp and a sony Handycam
any suggestions?
thx HiRsch
Kippesoep
Posted: Oct 9 2002, 01:27 PM
Try altering your video source format and resolution. I get a very strange error where capturing in low resolution (384x288 or 480x576, for instance) only captures about 12fps, but capturing in high resolution (such as 720x576) captures everything. Weird, but true (it also seems to vary slightly depending on which VCR I use).
1 replies since Oct 6 2002, 09:02 PM Track this topic | Email this topic | Print this topic
<< Back to Capture
