Displaced Lines
Klyber
Posted: Aug 23 2012, 07:25 PM
Hi there,
my english leaves much to be desired, so i'll do my best....
i'm trying to capture some old videocasettes (PAL) but sometimes from one second to the other every second line is shifted. when i restart the vcr sometimes it's gone, sometimes it's gone if i wait few seconds....
i'm thankful for every help!!!
my Configuration:
Win 7
Virtualdub -> huffyuv
Terratec G5 (my Device for Capturing)
LG LV3766 (my VCR)
Posted: Aug 23 2012, 07:30 PM
Like this?
http://en.wikipedia.org/wiki/File:Interlac...ar_wheel%29.jpg
If so you need to deinterlace it - use the deinterlace filter
Klyber
Posted: Aug 23 2012, 07:52 PM
hi,
yes like thios but less extreme
Klyber
Posted: Aug 23 2012, 08:04 PM
where do i ffind the deinterlace options?
Posted: Aug 23 2012, 08:25 PM
Usually better do deinterlacing after capturing as it uses less cpu
http://www.youtube.com/watch?v=RQi3_tcjSGc
But you can do it while capturing
On the video menu
Video->filter chain->enable
Video->filter chain->filter list
add
select deinterlace
ok
ok
ok
You can pick between different deinterlace methods in the filters settings, but the default usually works ok
Klyber
Posted: Aug 24 2012, 06:43 AM
THX!!!
Klyber
Posted: Aug 24 2012, 07:09 AM
i found the problem:
it was the SCART cable! it didnt fit right. now i replaced it and everythings fine smile.gif
6 replies since Aug 23 2012, 07:25 PM Track this topic | Email this topic | Print this topic
<< Back to Capture
