| drizztcanrender |
| Posted: Sep 14 2002, 06:19 PM |
Ok i just installed the btwincap drivers and it seems i have no audio.The video part is playing well though.I have the pinnacle studio PCTV pro(Bt878). Also do you know any good viewing,not capturing, application??I really would like to use the remote control again,this btpci driver's tv tuner has like 300 channels but only some of them are locked.I just can't remember which ones... Sorry for the hasty post(i know i should have searched first) but i'm getting distressed...
| Neo Neko |
| Posted: Sep 14 2002, 10:36 PM |
VirtualdubMod Alpha tester
the BTWINCAP drivers do not officially support the audio portions of the BT878(you) or BT879(me) IIRC. They will eventually.
As for just watching....... Get dscalar. New version just out. If it works with your card it is hands down the best tunner app I have seen. The latest version is a bit CPU hungry though. But Dscalar has some wickid deinterlacing algos. The new version looked outstanding last night. Perfect deinterlace. I wish there were some way to use it's deinterlace algos in virtualdub. They are kinda slow but damn good. And yes I know there is an outdated directshow version, but the new algos are awesome.
www.dscalar.org |
| ProfDrMorph |
| Posted: Sep 15 2002, 10:27 AM |
I think you mean DScaler ( www.dscaler.com ) |
| drizztcanrender |
| Posted: Sep 15 2002, 10:57 AM |
I know about that,i read it in the website.But it also says that it doesn't support the internal audio capture device and that you can capture audio with your audio card.That's what i'm doing,i think.I have my soundcard connected to the audio out of my tvcard and select it as an audio capture device.But nothing still works. |
