Fps Rate To High? (async Problem), capturing S-VHS with Terratec Grabster
yawa
Posted: Dec 31 2011, 04:52 PM
Hi there,
I'm trying to capture a video from S-VHS source with my Terratec Grabster AV300 and I get a video/audio sync problem. The problem is, as I see, that a video fps rate is too high (about 33-34 fps).
If I activate a sync option in "timings..." then the video stream will be "downgraded" to 25 fps, and I get many dropped frames of course => the audio stream is synced well, but the video is not smooth.
I've tried to change the "frame rate" under Capture->Settings, but I can't save my value, it shows me 25.000 only!
Any idea?
Thank you very much!
Ducati87
Posted: Feb 22 2012, 12:50 PM
I have the same problem! The FPS rate dosen't change! Due this problem I can't capture nothing!
1 replies since Dec 31 2011, 04:52 PM Track this topic | Email this topic | Print this topic
<< Back to Capture
