Persistent Gui Settings?, Restarting VD resets some settings...
^rooker
Posted: Jun 4 2010, 09:29 AM
Some GUI options are not persistent when restarting Virtualdub. I've checked the registry keys for VirtualDub>Capture and it seems that there are no options for some GUI settings.
The ones I'd need (and therefore have checked) are:
- Audio > Volume meter
- Capture > Display large timer
Everytime I restart VirtualDub, or even when I exit capture mode and return to it again, they reset to their default visibility state (=off) sad.gif
How difficult would it be to make these options persistent, or is there already a way to enable them automatically, by e.g. adding some registry keys manually?
Thanks in advance.
Posted: Jun 5 2010, 06:45 AM
Added to feature request list.
^rooker
Posted: Jun 6 2010, 07:33 PM
Thank you!
btw: I've noticed a "cosmetic issue" with the large timer:
It does not clear its canvas when stopping and restarting the capture, which leads to slightly confusing time values being displayed. wink.gif
Example:
Capture 1: 15 mins, 26 seconds (= 15:26)
Capture 2 (in progress) would display the following value after 3 mins, 00 seconds (= 3:00): 3:006
(I'm only posting this for the sake of completeness. Sorry if it sounds pedantic...)
Posted: Jun 7 2010, 07:02 AM
Yup, that's a bug. Added to the list.
sendspam
Posted: Oct 15 2011, 04:12 PM
Has this bug been fixed yet? I'm trying the 1.10.1 test releases and it's still not fixed.
^rooker
Posted: Feb 26 2012, 10:16 PM
Would it be helpful if I tried to implement that modification on my setup (if I can compile VirtualDub) and send you a patch?
5 replies since Jun 4 2010, 09:29 AM Track this topic | Email this topic | Print this topic
<< Back to Capture
