Wdm Drivers
chrome307
Posted: Sep 4 2002, 02:50 PM
Hi there, can anyone tell me where I can find WDM drivers for my old tvcard, here's the spec:
General information:
Chip: Bt878 , Rev: 0x02
Subsystem: 0x3002144f
Vendor: Askey Computer Corp.
Values to MUTE audio:
Mute_GPOE : 0x551e00
Mute_GPDATA: 0x541800
Has TV Tuner: Yes
TV_Mux : 2
TV_GPOE : 0x551e00
TV_GPDATA: 0x541400
Number of Composite Ins: 1
Composite in #1
Composite1_Mux : 2
Composite1_GPOE : 0x551e00
Composite1_GPDATA: 0x541400
Has SVideo: Yes
SVideo_Mux : 1
SVideo_GPOE : 0x551e00
SVideo_GPDATA: 0x541000
Has Radio: Yes
Radio_GPOE : 0x551e00
Radio_GPDATA: 0x541400
Thanks in advance, chrome ;0)
SillKotscha
Posted: Sep 4 2002, 03:00 PM
smart Moderator
QUOTE (chrome307 @ Sep 4 2002, 04:50 PM)
Chip: Bt878
hi chrome307,
for BT8x8 chip current/alternative drivers can be found on the Sourceforge server: http://btwincap.sourceforge.net/
cheers Sill
chrome307
Posted: Sep 7 2002, 02:23 PM
Thanks for the reply, I tried installing them but it failed, even by hand too!!
Would I be able to use WinHauppage's standard WDM drivers with my BT878 card??
chrome ;0)
drizztcanrender
Posted: Sep 7 2002, 11:25 PM
Maybe try this thing here:
http://btwincap.sourceforge.net/custom.html
Also it seems that this chip(Bt878) has problems with the current drivers and audio support.Not a problem if you are using your soundcard for audio though.
3 replies since Sep 4 2002, 02:50 PM Track this topic | Email this topic | Print this topic
<< Back to Capture
