"no Capture Driver Available" ?, Need advice installing capture drivers
MrMike
Posted: Sep 4 2002, 01:58 PM
I am having a problem getting VirtualDub to set up to do AVI capture. When I try to bring it up with FILE>AVI CAPTURE I get an error message "No capture driver available".
I have done some prelinimary homework before posting this request. I downloaded the DirectX 8.1 upgrade and the capture upgrade too, I also downloaded DX80DBA.EXE, VFWUPD.EXE and WRAPPER.ZIP. But it still gives me the error message.
What's missing????
TIA,
MrMike
chrome307
Posted: Sep 4 2002, 02:53 PM
Hi there, what are you using to capture with? Is it not listed under VIDEO, SOURCE?
chrome ;0)
Tut_Ank
Posted: Sep 6 2002, 04:28 AM
Have you done this:?
Open your video application ( the one You use to watch TV) select the source that you want to capture from. CLOSE the video aplication.
THEN and ONLY THEN get virtualdub in capture mode.
This is to initialize your hardware. After doing this you might or might not have solved the problem. blink.gif
donsing
Posted: Sep 6 2002, 08:34 PM
Dumb question. Why can't I find video source in virtualdub? Where is it? I am trying to capture from ADS Instant Video (USB device). Will it work?
Thanks for any and all assistance.
3 replies since Sep 4 2002, 01:58 PM Track this topic | Email this topic | Print this topic
<< Back to Capture
