I Have A Mess, I'm Stuck
tbh
Posted: Aug 30 2002, 09:27 PM
Everything was working fine until I tried some experimenting. Now my capture will create only key frames and my audio is grossy distorted. On a 4 second test video, I get 68 key frames, 0 delta frames, and 4 audio frames.
I got into this mess by having mpeg-4 V1 in compression with a setting of 1 key frame per 8 frames at capture time. The format was either 15 RBG or YUY2, I don't remember because I experimented with a lot of things today. It appeared to create just the key frames (not sure) but with no picture. I had to reset to get a picture but the capture is all wrong as I've mentioned above.
Something is corrupted, and I don't know where to look. I couldn't find any uninstall in order to remove and reinstall. I found in the AuxSetup a remove option for the registry entries. Is that the uninstall? I could then remove the directory/folder and let the new install create everything fresh and clean. Thanks, if anyone can help.
0 replies since Aug 30 2002, 09:27 PM Track this topic | Email this topic | Print this topic
<< Back to Capture
