| pymander |
Posted: Dec 10 2002, 12:56 PM |
Hi there,
After capturing film, which went o.k. I want to filter it with Temporal Smoother. On screen everything looks fine but after opening new file, after writing, the image of the video is completely distorted. (The image has a V-shaped cut in it...)How can this be... It used to be o.k. The only new thing I've done is using an upgraded VirtualDub version which keeps the audio and video in sync by correcting the audio instead of losing frames...? Anyone?
| outlyer |
| Posted: Dec 11 2002, 03:40 PM |
Spanish Section Mod
don't know if I understood it well, but it seemed to me like the error you get when using non "standard" dimensions; usually it must be divisible by 32, 16, 8 or 4, depending on the codec. Are video dimensions disible by 32 or 16, which are the most standard? If not, try to correct this. |
