| bensolomon |
| Posted: Aug 28 2014, 05:31 PM |
Hello all. I have installed virtual dub v1.10.4. i installed deshaker and ffinput. I also installed the deinterlace plugin. I can load the source video (MPG) from Go Pro. The deshaker runs fine, but real slow. Pass 2 works fine, but it is slow, and the outputted video is very slow. I have a Dell, Optiplex, Intel Core 2 Duo, Windows 7, 32 Bit OS, 4 Gig Ram.
Any help is greatly appreciated.
Thanks, Ben |
| raffriff42 |
| Posted: Aug 28 2014, 06:00 PM |
It's normal for Deshaker processing (pass 1) to be slow. Pass 2 should be much faster, but don't expect smooth, real-time playback in VirtualDub.
If your output video plays back slowly in Media Player, I would first want to see your compression settings. Please post a MediaInfo report for your output file. |
| Posted: Aug 28 2014, 06:03 PM |
I'd guess that your final video is also extremely large as well That'd be because you didn't pick a codec for the encoders (audio and video)
For video I'd recommend x264vfw -> link to the encoder and a picture of starting settings http://forums.virtualdub.org/index.php?act...1157&hl=x264vfw
For audio mp3's a normal choice Link is in my sig -> LameMP3
| bensolomon |
| Posted: Aug 28 2014, 08:11 PM |
Here is the media info post. Thank you for the suggestion. As a side note, I have first cropped the video to a usable amount, like 1 or 2 minutes of video. I don't try to process all bazilliion gigabytes. Thank you for the help!!!
General Complete name : E:\My Videos\2014 Sailing Dawn 08_24_14\GP040640.MP4 Format : MPEG-4 Format profile : JVT Codec ID : avc1 File size : 1.91 GiB Duration : 18mn 2s Overall bit rate : 15.1 Mbps Encoded date : UTC 2013-01-27 21:43:11 Tagged date : UTC 2013-01-27 21:43:11 AMBA :
Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L4.0 Format settings, CABAC : Yes Format settings, ReFrames : 1 frame Format settings, GOP : M=1, N=8 Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 18mn 2s Bit rate mode : Constant Bit rate : 15.0 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 29.970 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.241 Stream size : 1.89 GiB (99%) Title : GoPro AVC Language : English Encoded date : UTC 2013-01-27 21:43:11 Tagged date : UTC 2013-01-27 21:43:11 Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709
Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 18mn 2s Bit rate mode : Constant Bit rate : 128 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Compression mode : Lossy Stream size : 16.5 MiB (1%) Title : GoPro AAC Language : English Encoded date : UTC 2013-01-27 21:43:11 Tagged date : UTC 2013-01-27 21:43:11
Other ID : 3 Type : Time code Format : QuickTime TC Duration : 18mn 2s Time code of first frame : 21:41:50:26 Time code settings : Striped Language : English Encoded date : UTC 2013-01-27 21:43:11 Tagged date : UTC 2013-01-27 21:43:11
| Posted: Aug 28 2014, 08:21 PM |
Thanks, but it was the information about the output file which plays slowly that was asked for :-)
Did you go to the video menu, select a compressor and the configure it (and the same for audio)? If not you have saved uncompressed video that has huge bytes per second - it can easily be larger than your hard drive can keep up with when playing back If you haven't done those steps, you'll need to install and choose a compressor before saving (see previous post)
| bensolomon |
| Posted: Aug 28 2014, 09:29 PM |
Okay. I will do that, and report back. That makes a lot of sense. Video IS huge. Thank you all!!! |
| bensolomon |
| Posted: Aug 28 2014, 10:38 PM |
After installing the x264vfw it worked great!! Thank you, thank you, thank you!!!! Your help was awesome!
Ben |
| Posted: Aug 29 2014, 04:50 AM |
You're quite welcome - have a good weekend
