Ultra Hd
gzii
Posted: Jan 16 2013, 08:09 PM
At the moment new ultraHD format is possible to rip only one video stream.
The first one.
First satellite channel trasmits on ultraHD @ Eutelsat10e.
Here is a sample (not mine) of transport stream.
http://rapidshare.com/files/60583165/Ultra%20HD.ts
General
Complete name : E:\Desktop\Ultra HD.ts
Format : MPEG-TS
File size : 82.9 MiB
Duration : 17s 469ms
Overall bit rate mode : Variable
Overall bit rate : 39.4 Mbps
Video #1
Menu ID : 1 (0x1)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.2
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : 27
Duration : 17s 60ms
Bit rate mode : Constant
Nominal bit rate : 9 000 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 50.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.087
Video #2
Menu ID : 2 (0x2)
Format : AVC
Codec ID : 27
Duration : 17s 60ms
Nominal bit rate : 9 700 Kbps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.094
Video #3
Menu ID : 3 (0x3)
Format : AVC
Codec ID : 27
Duration : 17s 220ms
Color space : YUV
Bit depth : 8 bits
Video #4
Menu ID : 4 (0x4)
Format : AVC
Codec ID : 27
Duration : 17s 160ms
Color space : YUV
Bit depth : 8 bits
Audio
Menu ID : 1 (0x1)
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Codec ID : 3
Duration : 17s 398ms
Bit rate : 256 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Compression mode : Lossy
Delay relative to video : -453ms
Stream size : 544 KiB (1%)
Menu #1
Menu ID : 1 (0x1)
Duration : 17s 397ms
List : 258 (0x102) (MPEG Audio) / 257 (0x101) (AVC)
Service name : TOP_LEFT
Service type : advanced codec HD digital television
Menu #2
Menu ID : 2 (0x2)
Duration : 17s 479ms
List : 261 (0x105) (AVC)
Service name : BOT_LEFT
Menu #3
Menu ID : 3 (0x3)
Duration : 17s 483ms
List : 263 (0x107) (AVC)
Service name : TOP_RIGHT
Menu #4
Menu ID : 4 (0x4)
List : 265 (0x109) (AVC)
Service name : BOT_RIGHT
-vdub-
Posted: Jan 17 2013, 01:02 AM
Use another tool that can demux (extract) the streams to avc and mpa audio. Which will parse and demux the mux of channels. AVC video can be loaded using FFMpeg Input Driver extracted to the correct virtualdub plugins folder.
Other I know Neuron2 has a dgavcdec type filter for avc. Maybe also avisynth could do this via a script. There many options and tools available to do this search for video demux tools.
gzii
Posted: Jan 18 2013, 12:08 AM
But this way it is possible to reencode only 1/4 of the whole picture.
Here is the whole picture of the .ts above:
http://shrani.si/f/3B/gK/2LIKhlyv/untitled-1.jpg
-vdub-
Posted: Jan 18 2013, 04:19 AM
I take it you have the demuxed the video to elementary streams and now trying to encode a video stream ?
Does the picture look ok when load a demuxed video stream into virtualdub. A problem with a video encoder setting or a filter you are using !
gzii
Posted: Jan 18 2013, 10:20 PM
http://shrani.si/f/V/Lx/1xiL11qj/untitled-1.jpg
Posted: Jan 18 2013, 10:46 PM
Right click the pane and zoom to 25% - does the full image show then ?
gzii
Posted: Jan 19 2013, 03:41 AM
http://shrani.si/f/R/PH/266LRLZ3/u.jpg
Menu #1
Menu ID : 1 (0x1)
Menu #2
Menu ID : 2 (0x2)
Menu #3
Menu ID : 3 (0x3)
Menu #4
Menu ID : 4 (0x4)
-vdub-
Posted: Jan 19 2013, 04:11 AM
I see the problem dloneranger are you seeing the full picture in virtualdub ?
I can at best with many crashes only see top left of the picture, if try to view more with arrow keys the video display goes grey.
Had to change to use input pane only, no auto resize, view at 100% will only show the picture no other percentage will work correctly. Other %s will show a smeared picture. The picture shows correctly and full using XP3 standard picture preview, graph edits, and other picture software's, AviDemux etc.
Many virtualdub crashes I have seen with trying this. Virtualdub crash.log showing various d3d9, EAX and Move code errors non repeatable the same. Played with virtualdub for Display_DirectX and 3D Accel etc yet not able to view better than above.
-vdub-
Posted: Jan 19 2013, 04:14 AM
QUOTE (gzii @ Jan 19 2013, 03:41 AM)
Menu #1
Menu ID : 1 (0x1)
Menu #2
Menu ID : 2 (0x2)
Menu #3
Menu ID : 3 (0x3)
Menu #4
Menu ID : 4 (0x4)
That's a weird way of broadcasting a video, must be something new for HD with larger screen sizes. What do you get with AviDemux with the video I can see the whole picture with that.
Posted: Jan 19 2013, 08:52 AM
This seems to be a whole new way of broadcasting "ultra high definition television" video:
> http://en.wikipedia.org/wiki/Ultra_high_de...tion_television
In comparison with Full HD (1920 x 1080 pixels) which is being broadcasted as one single image, the 4K Ultra HD consists of four Full HD images (top left and right, and bottom left and right). At besides of 4K Ultra HD, there will also be 8K Ultra HD, consisting (I suppose) of 16 Full HD images.
It will be a challenge to write an import filter for such files to open them in VirtualDub (supposing these large images will be supported).
Posted: Jan 19 2013, 09:23 AM
QUOTE (-vdub- @ Jan 19 2013, 05:11 AM)
No, I was just looking at his screenshot where the image is larger than the display size and wondered if was just too big :-)
(I do a lot of spam hunting on my phone while at work, so I can't double check while I'm there)
Re DX errors
TBH, I always turn off the acceleration features for the virtualdubs display and just let it use gdi
Posted: Jan 19 2013, 09:42 AM
QUOTE (Abrazo @ Jan 19 2013, 09:52 AM)
I will be a challenge to write an import filter for such files to open them in VirtualDub (supposing these large images will be supported).
Yeah, that look unpleasant alright
Now fccHandlers gone, there's a shortage of input plugin authors, so it might be a case of getting the video into something that can be handled by another part of the system (directshow, avisynth etc)
Hopefully there's enough sync information in the streams that we don't get a load of 'the top left corner is out of sync with the rest' problems
-vdub-
Posted: Jan 19 2013, 10:28 PM
Maybe an Avisynth script could do this until a plugin is available such as mosaic or other
UltraHD
4k 3840×2160
8k 7680×4320
Standards that deal with UHDTV include:
Rec. ITU-R BT.1201-1 (2004)[124]
Rec. ITU-R BT.1769 (2006))[125]
Rec. ITU-R BT.2020 (2012)[11]
SMPTE 2036-1 (2009)[126]
SMPTE 2036-2 (2008)[127]
SMPTE 2036-3 (2010)[128]
Rec. 709 – ITU-R Recommendation for HDTV
Rec. 2020 – ITU-R Recommendation for UHDTV
12 replies since Jan 16 2013, 08:09 PM Track this topic | Email this topic | Print this topic
