| atr232000 |
Posted: Feb 22 2003, 02:01 AM |
hi
i have got a avi file that has a unknown audio stream and i carnt convert it i load the avi in to virtualdub and i carnt change to full prosessing mode becuase virtualdub carnt read it so i just direct copy and save as .wav its plays as a .wav but when i try to rencode it i get error that its not a valid .wav file i have change the extention to load .ac3 . mp1.mp2.mpeg.raw.pcm.mp3.voxmpc.and wma but know seam to work and i just get a load off screeming if it does encode at all i used avinfo to see if it will tell the audio format but no all it says is unknown .wav format i need to do this audio thing so i can comprees it on to 1 cd it is on 2 at the mo. thanks in advance |
| Posted: Feb 22 2003, 02:27 AM |
| QUOTE (atr232000 @ Feb 21 2003, 10:01 PM) | | What Format Is It? |
Um, it's the "unknown" format. You need to get the unknown codec.
But seriously, open the AVI in VirtualDub and choose File->Information and see if it shows a tag number, and if so what number?
| atr232000 |
| Posted: Feb 22 2003, 10:13 AM |
ok m8 the tag number is (unknown tag 200) does that help and i thought i had all the codecs possible ................lol thanks again |
| Posted: Feb 22 2003, 08:01 PM |
Are you sure it says 200 and not 2000?
200 is Creative Labs ADPCM (I think)
2000 is Dolby AC3.
