| TimShady |
| Posted: Feb 20 2003, 06:18 PM |
This is my problem:
When I open the file: `Die another Day.avi´ , and go to AUDIO and select FULL COMPRESSION MODE. Then I go to AUDIO - Conversion and select sampling rate 44100Hz. Then AUDIO - Compression ans select no compression. When I click Save WAV file as:. `Die another Day´ and click Save, I get the following error:
VirtualDub error "The requested audio compression is not compatible with the input format. Check that the sampling rate and channel count of the input match those of the requested format."
I really need this, because I want to make a VCD. I hope anybody can help me.
TimShady |
| pf100 |
Posted: Mar 1 2003, 05:37 AM |
If I had to guess, which I do, I'd say you have 48khz 5-channel dolby surround sound audio. You're going to have to downmix it to 44.1khz stereo (2 channel). I've never had to do that with a wav file before - I've always done it directly from the .vob files. Good luck. |
| jcsston |
| Posted: Mar 1 2003, 06:51 AM |
Matroska Dev
Do a search for AC3 and/or tag 200.
