Pages: (7) [1] 2 3 ... Last » ( Go to first unread post )
Encode With External Encoders, A quick how-to on the feature
Loadus
  Posted: May 29 2010, 03:58 AM
Here's a rundown on the "External Encoder" feature
On the "Encoder Sets" tab, you have your possible combinations of your
elementary+multiplexing settings (I have a lot of redundant stuff here from
experimenting with various settings, so ignore):
On the "Encoders" tab, you have your individual settings for each video,
audio and/or multiplexing format (even more redundant stuff here):
To create a video (in this example a video that's playable in iPhone),
you'll need one videostream (h.264 compliant), one audiostream (AAC) and
you have to multiplex them together (into mp4 container).
Download your encoders (most can be found through links in doom9's forum/
download section), place them where you want (for convenience, I have them
in VirtualDub's folder).
For this example, you'll need:
- x264
- ffmpeg
- MP4Box
On the "Encoders" tab, click "Add..." and add a videostream encoder settings:
Here's x264 video settings for iPhone (x264.exe):
--preset slower --bitrate 300 --thread-input --b-pyramid strict --vbv-maxrate 700 --cqm "jvt" --fps %(fps) --direct temporal --output "video.264" - %(width)x%(height)
Note that when using the pipe to feed the video, the encoder needs to know
your video parameters, ie. size, speed. And some encoders and/or multiplexers
are REALLY picky about filenames, so in some cases "something.audio" won't work.
Name this to something easy to find, like "x264".
Again, on the "Encoders" tab, click "Add..." and input your audio settings:
AAC settings for iPhone (ffmpeg):
-i - -y -acodec libfaac -ab 128k -ar 48000 -ac 2 "audio.aac"
Name it to something simple, like "AAC".
And once more, on the "Encoders" tab, click "Add..." and set your multiplexer to kill
all living things:
Multiplexer settings (MP4Box):
-add "video.264" -add "audio.aac" -fps %(fps) "%(outputname)"
MP4Box is somewhat critical on filenames, it won't accept the default naming.
Name this also to something simple, like "h264+AAC".
Now, on the "Encoder Sets" tab, click "Add..." and input your video settings:
And you're ready to go.
On this example, resize the video to 480 x 272 and start encoding by selecting your
encoder set from the "Export..." option in the "File" menu:
Select your set:
The video starts to encode. If not, you haven't set something right (framesize,
speed, format, you haven't donated enough for VirtualDub etc). Check your
settings. And have the encoders write errors in the VirtualDub's log, makes life easier.
You can grab my settings from here:
http://www.loadusfx.net/virtualdub/vdub-ex-enc.vdprof
Most settings are "odd" due to experimenting, and the aspect ratios on the
iPhone sets seem weird - they've been calculated on the really strange formula
that Quicktime/iPhone uses, but they should look OK on the actual iPhone.
Tips on encoding stuff on the iPhone:
You can encode your video in an "odd" size, because iPhone will obey your AR setting
- Use 240 x 272 for 16:9 with AR of 161:81
- Use 240 x 208 for 2,35:1 with AR of 381:191
- Use 240 x 320 for 4:3 with AR of 52:30
iPhone will accept bitrates up to 1500kbps (in which case you can use the full
480 x 320 resolution)
Have fun, and tell me how it all went down. Remember, these settings will blow
up your computer and sell your children to the penguins of Antarctica, so don't
come running to me and say I didn't warn you.
Superhyper thanks to Phaeron for creating this feature.
deviantART behance
stephanV
Posted: May 29 2010, 07:26 AM
Thanks for your work. I'm going make this topic a sticky for future reference. smile.gif
useful links:
v0lt
Posted: May 29 2010, 07:27 AM
Virtualdub.exe-1.9.X-test20_command_arguments_patched.7z - link removed
Gromozeka
Posted: May 29 2010, 08:47 AM
Loadus
How work your mencoder
what its build? where download?
Loadus
Posted: May 29 2010, 08:55 AM
QUOTE (Gromozeka @ May 29 2010, 02:47 AM)
Loadus
Haven't used mencoder yet for serious encoding. If I remember correctly, I couldn't get it to accept video from the pipe. I tested it, but it didn't work. If someone knows the correct syntax, feel free to post here.
The settings I have on the encoders are also pretty basic - if anyone knows really high quality<-->small filesize -settings, I'm interested in seeing those as well. ^^
deviantART behance
Gromozeka
Posted: May 29 2010, 04:58 PM
Loadus
If phaeron do it, then mencoder shall be work
Posted: May 30 2010, 04:17 AM
Wait, I just checked mencoder(1) and it looks like it supports -rawvideo format=yv12, which should work fine. Why is YUV4MPEG needed?
v0lt
Posted: May 30 2010, 04:51 AM
it only seems so, no one has it normally does not run from a VD
- will work Mencoder
- will work other encoders
- you can not specify the parameters of the frame at the command line (width, height, framerate)
DarrellS
Posted: May 30 2010, 05:35 AM
I'm able to create the video.264 file and the audio.aac file but I'm not able to mux the files together. What am I doing wrong?
EDIT: Phaeron helped me fix the problem. Seems that MP4Box.exe would not work without being in a folder with the files that it depended on so I directed the external encoder to C:\MyMP4Box GUI\Tools\MP4Box.exe and it muxed the files just fine.
I would like to know how to use Virtualdub to edit an MP4 file and save with the external encoder without re-encoding the file. I saw some parameter in Loadus link that looked like it copied files but I couldn't seem to get ffmpeg to work. I'm sure I'll probably have to do what I did with MP4Box and lead the encoder to the ffmpeg folder.
Gromozeka
Posted: May 30 2010, 08:25 AM
Phaeron
It's not truth!
this work fine
ffmpeg -i 1.avs -f yuv4mpegpipe - | mencoder - -of mpeg -o 1.mpg -mpegopts format=dvd -srate 48000 -ovc lavc -lavcopts vcodec=mpeg2video:vrc_buf_size=1835:keyint=15:trell:mbd=2:precmp=2:subcmp=2:cmp=2:dia=-10:predia=-10:cbp:mv0:vqmin=3:vb_qfactor=1.25:vb_qoffset=0:vqcomp=0.75:dc=8:vstrict=0:vrc_maxrate=8800:vbitrate=7000:aspect=4/3
This not work
ffmpeg -i 1.avs -pix_fmt yuv420p -f rawvideo - | mencoder - -of mpeg -o 1.mpg -mpegopts format=dvd -srate 48000 -ovc lavc -lavcopts vcodec=mpeg2video:vrc_buf_size=1835:keyint=15:trell:mbd=2:precmp=2:subcmp=2:cmp=2:dia=-10:predia=-10:cbp:mv0:vqmin=3:vb_qfactor=1.25:vb_qoffset=0:vqcomp=0.75:dc=8:vstrict=0:vrc_maxrate=8800:vbitrate=7000:aspect=4/3
Sorry, this file format is not recognized/supported
will work Mencoder
This is a serious reason
stephanV
Posted: May 30 2010, 12:01 PM
QUOTE (DarrellS @ May 30 2010, 07:35 AM)
That is not possible.
useful links:
Loadus
Posted: May 30 2010, 04:41 PM
QUOTE (DarrellS @ May 29 2010, 11:35 PM)
In theory, you could use VirtualDub's Direct Stream Copy together with ffmpeg (-vcodec copy), but I can't really say if that will work - I don't know the format VirtualDub would use for DSC. You'd have to cut from the keyframes though.
deviantART behance
DarrellS
Posted: May 30 2010, 05:27 PM
QUOTE (stephanV @ May 30 2010, 05:01 AM)
Looks like another job for Avidemux.
I was wanting to save in an MKV container and Smart Render H264/AAC and Avidemux will do both.
Loadus
Posted: May 30 2010, 07:24 PM
xvid_encraw behaves strangely. Right at the middle of the encode it gets 'reset' or something. It kills the pipe and throws the statistics on the log. It happens always at the same frame, at different point in different videofiles (in a documentary clip it always happened at frame 50, in a trailer clip it happened at frame 335). No error is given, it just .. stops. Any thoughts on what's happening?
[i] VideoEnc:    43: key=0, time=     16, len=       7 | type=P, quant=  1,      len=       7
[i] VideoEnc:    44: key=0, time=     16, len=       7 | type=P, quant=  1,     len=       7
[i] VideoEnc:    45: key=0, time=     16, len=       7 | type=P, quant=  1,     len=       7
[i] VideoEnc:    46: key=0, time=     15, len=       7 | type=P, quant=  1,     len=       7
[i] VideoEnc:    47: key=0, time=     31, len=       7 | type=P, quant=  1,     len=       7
[i] VideoEnc:    48: key=0, time=     31, len=       7 | type=P, quant=  1,     len=       7
[i] VideoEnc:    49: key=0, time=     32, len=       7 | type=P, quant=  1,     len=       7
[i] VideoEnc:    50: key=2, time=     16, len=   22492 | type=I, quant=  1,     len=   22492
[i] VideoEnc: Tot: enctime(ms) =1111.00,               length(bytes) =   67812
[i] VideoEnc: Avg: enctime(ms) =  21.78, fps =  45.90, length(bytes) =    1329
[i] VideoEnc: I frames:      3 frames, size =   22492/  67476, quants =  1 /     2.00 /  4
[i] VideoEnc: N frames:     48 frames, size =       7/    336
[i] VideoEnc: xvidcore build version: xvid-1.3.0-dev
[i] VideoEnc: Bitstream version: 1.3.-127
[i] VideoEnc: Detected CPU flags: ASM MMX MMXEXT SSE SSE2 SSE3 SSE41 TSC
[i] VideoEnc: Detected 4 cpus, using 4 threads.
EDIT:
Looking at the encoding process, it seems like it doesn't like the audio encoder doing it's stuff at the same time .. is it possible to make the encoders work in serial, instead of parallel? First video, then audio, then multiplex. Or even in a singular mode, when you would only output video or audio?
deviantART behance
Posted: Jun 1 2010, 12:11 AM
Serial mode would be difficult to implement, the way things are set up now.
It's not truth!
this work fine
We were talking about mencoder. ffmpeg is not mencoder.
What I want to know is why these programs have an option that doesn't work. They have command line options that are supposed to accept raw video, so what's wrong here?
99 replies since May 29 2010, 03:58 AM Track this topic | Email this topic | Print this topic
