Avisynth Troubles., No decent mpeg2 filter.
Marticus
Posted: Sep 3 2002, 06:21 AM
I've been learning to use avisynth over the past 6 days (with many headaches) but the one problem I can't solve is finding a reliable mpeg2 filter. Elecard leaves a logo in the top corner all the time, and Ligos Mpeg-2 Filter tends to lock up after 40 frames. Are there any alternatives?
SillKotscha
Posted: Sep 3 2002, 06:44 PM
smart Moderator
PLUG-INs, CODECS and FILTERS
sh0dan
Posted: Sep 20 2002, 03:13 PM
Avisynth Developer
How about using MPEG2DEC together with DVD2AVI (quite easy). See Q33 in the AviSynth FAQ
- or use this experimental filter for direct m2v import:
Nic's MPEGDecoder plugin
Marticus
  Posted: Sep 26 2002, 08:03 AM
grr. OK I was using this for a short while and it worked perfectly,
but I had to reinstall windows, and now every time i try to load a vob with mpeg2dec (via d2v) or mpegdecoder i get an unrecognized exception.
What am I missing here?
sh0dan
Posted: Oct 11 2002, 02:14 PM
Avisynth Developer
Are you using DVD2AVI 1.76? - otherwise you might run into trouble.
4 replies since Sep 3 2002, 06:21 AM Track this topic | Email this topic | Print this topic
