| CyberData2 |
| Posted: Aug 26 2002, 09:50 AM |
i spent about half an hour deleting frames from a video file and when i saved the edited file it was huge and very poor quality. HELP!!
thanks
CyberData2@hotmail.com ithacacollegesucks.com |
| BaronVlad |
| Posted: Aug 26 2002, 03:45 PM |
Terrorhörnchen
Welcome CyberData2, if you want us to help you, we want you to give us a bit more details about your source video (in VirtualDub File information) and the compresion that you tried with the video.
Without these informations I can only guess: You forgot to use any compression, just saved an uncompressed avi. Your file will get huge and the quality may get poor
| CyberData2 |
| Posted: Aug 26 2002, 07:30 PM |
No matter what compression i use the file is either huge (several hundred megs to over a gig) or poor quality. When I finaly found a compression that wouldn't make the file that big the quality suffered (I beleive it was intel l.263 video driver 2.55.016). It confuses me becuase a year or so ago I was able to edit files w/out a problem.
virtualdub file info gave a whole bunch of info that doesn't mean much to me. Are there specific things you need to know? Not that this is the only file that i have problems w/. Am I missing the correct compressions?
Thanks
CyberData2 ithacacollegesucks.com |
| ChristianHJW |
| Posted: Aug 26 2002, 07:31 PM |
... i guess you forgot to set 'video' to 'direct stream copy' when saving the new AVI ...
| CyberData2 |
| Posted: Aug 26 2002, 07:50 PM |
I had it on full processing mode. Would Direct Stream Copy make the difference?
Thanks
cyberdata2 ithacacollegesucks.com |
| ProfDrMorph |
| Posted: Aug 26 2002, 08:33 PM |
Direct Stream Copy means that VirtualDub doesn't recompress the video stream. But this doesn't work always ( depends on the codec/compression you used and it's settings ). Just try it.
Otherwise try using DivX5.02 Standard ( www.divx.com ) if you need a good codec for recompression ( = Full Processing Mode ). |
| CyberData2 |
| Posted: Aug 26 2002, 11:58 PM |
I set it for direct stream copy but most of the files i try it w/ won't work at all and others end up being 500 megs.
| BaronVlad |
| Posted: Aug 27 2002, 07:14 PM |
Terrorhörnchen
Can you please tell us, what codec was used for compressing the source files ? (File -> File information) Try this directstreamcopy procedure with other files (i.e. Divx). Does it work ?
