Edit Divx File, Having problem reading one of the frame
jl4296
Posted: Oct 19 2002, 05:55 PM
Hi, I am new to Virtualdub. This is problem. I have a divx file that has a bad frame. I am trying to edit that frame off. I can get a file up to that bad frame. But I can not create another file after that bad frame.
It's there anything that I can do to.
Thanks in advance for your help.
Posted: Oct 19 2002, 07:00 PM
It might work to choose Video->Scan video stream for errors. Alternatively, select the bad frame and choose Edit->Mask selected frames. I don't know for sure since I've never really used this feature, but it seems to be designed to work around exactly the problem you describe.
jl4296
Posted: Oct 19 2002, 07:11 PM
Ok, can you give me more detail on how to do it?
Posted: Oct 20 2002, 03:54 AM
Well, after experimenting a bit with the "mask frames" feature, it appears that the video will have to be recompressed (bummer).
1) Start VirtualDub
2) Open the original AVI
3) Choose "Video->Scan video stream for errors" (might take a while)
4) Choose "Video->Compression" (select your favorite codec)
5) Choose "File->Save old format AVI" (save a new AVI)
6) If the new AVI works, delete the original
alacrity
Posted: Oct 21 2002, 04:47 PM
divfix might also be an option. I guess it wouldn't hurt to try it if the above does not work.
4 replies since Oct 19 2002, 05:55 PM Track this topic | Email this topic | Print this topic
