| sQr0nS |
Posted: Feb 5 2015, 11:13 PM |
Hai, im new to the forums, and i have a question, i "decompiled" a video into images (sorry if that's not the right word), the video was at 25 fps, i edited some of the images and then i "compiled" them again into a video, but the final file was at 10 fps. So i was wondering if is there any way to change that [FONT=Arial][COLOR=purple] |
| ALbino |
| Posted: Feb 6 2015, 12:38 AM |
I've never done this, but I would imagine if you just went to Video -> Frame Rate (ctrl+r) and used the Change Frame Rate that would probably work. HTH |
| Posted: Feb 6 2015, 05:19 AM |
The default fps for images turned into avi's is set in the preferences
menu->options->preferences->images
