| steelgtr |
| Posted: Jan 24 2015, 08:59 PM |
Hi Guys
Can't get more than 1 jpeg to import either dragging photo #1 or opening through file, open video file. Photos are in this format if it helps:
2015_0124_104752_001.JPG, etc.
Appreciate any help!
thx
bob |
| Abrazo |
| Posted: Jan 24 2015, 09:34 PM |
Are you sure that everything what is preceeding the sequence number, is always identical ?
Something like this:
2015_0124_104752_001.JPG 2015_0124_104752_002.JPG 2015_0124_104752_003.JPG 2015_0124_104752_004.JPG etc. |
| steelgtr |
| Posted: Jan 24 2015, 10:52 PM |
| QUOTE (Abrazo @ Jan 24 2015, 09:34 PM) | Are you sure that everything what is preceeding the sequence number, is always identical ?
2015_0124_104752_001.JPG 2015_0124_104752_002.JPG 2015_0124_104752_003.JPG 2015_0124_104752_004.JPG etc. | Totally! That's what's frustrating Thought the ".001" might be the culprit. Taken from an SJCAM4000 wifi (Gopro type)
Thanks
bob |
| steelgtr |
| Posted: Jan 24 2015, 11:19 PM |
Big OOOPS
The files go like this:
2015_0124_104752_001 2015_0124_104756_002 2015_0124_104759_003
I missed the third group of numbers. Looks like a time stamp?
Sorry but what do I do? |
| Abrazo |
| Posted: Jan 25 2015, 08:39 AM |
You will have to rename the files (the original ones or a copy of them):
simply via a Windows trick (thanks to malky): http://forums.virtualdub.org/index.php?act...=ST&f=4&t=23087
In other words: - select the files to rename in Windows Explorer, - do a right mouseclick, - click Rename, - type a space or a new name (if you like) and press ENTER.
It will give you a result like this:
NewName (1).jpg NewName (2).jpg NewName (3).jpg NewName (4).jpg etc. |
| steelgtr |
| Posted: Jan 25 2015, 05:39 PM |
| QUOTE (Abrazo @ Jan 25 2015, 08:39 AM) | You will have to rename the files (the original ones or a copy of them):
NewName (1).jpg NewName (2).jpg NewName (3).jpg NewName (4).jpg etc. | Thanks! Works great, simple and fast
bob
