Different Sampling Rate
erzane
Posted: Jan 17 2015, 01:09 PM
I have 2 files OP & ED
I am trying to append both files but when I append the 2nd one (ED)
it tell me this
http://cjoint.com/?EAros1ElXnX
Posted: Jan 17 2015, 01:20 PM
The error is exactly what the message is telling you
The two videos have different fps - it's very small but still different
You'll have to make the two match exactly before they'll join
With the difference being so small you might not have to change the audio as well
So, load the 23.97602 file
Set video and audio to direct stream copy
On menu video->frame rate
Select 'change frame rate(fps)' and type in the frame rate of the video you want to match (23.976)
Save the avi with a new name
Now you can append the first file and the newly saved one
Hopefully the audio won't get out of sync in the second half
If it does you'll have to reprocess the audio - post again if so
erzane
Posted: Jan 17 2015, 01:32 PM
Thanks for your reply,
I did as you said I typed 23.076 for the 2nd video (ED), then saved it, and tryed to append again.
Now it tells me that:
http://cjoint.com/?EAroPUO19p3
p.s. to reprocess the audio ?
here are some infos about the 2 files
OPENING (OP)
http://cjoint.com/?EAroZdJCNGk
ENDING (ED)
http://cjoint.com/?EAroZL4siBn
Posted: Jan 17 2015, 01:48 PM
So the audio's totally different as well.....
That, you can't just do a quick fix on
You'll have to save both videos again with the same audio values and then join them
Because I don't know what format the audio is in I'll have to describe the longer way of doing it
Load the video
Set video to direct stream copy mode
Set the audio to full processing
On the menu audio->compression select no compression
On the menu audio->conversion select 48000
save the avi
Do that for the other file as well
Load the first new file, append the second new file
On the menu audio->compression select a compressor like Lame mp3 and pick a bitrate like 128abr
Save this file and you'll have one with compressed audio
Note, the second files audio will be worse than the first half, as the source file is lower quality to start with
erzane
Posted: Jan 17 2015, 02:17 PM
I dont want to touch to the ''OP'' file because I have a lot of files to put between OP and ED
in fact OP and ED will be the beginning and the end of an episode
so, that's why I just want to fix ED file for match with OP and the episode which haven't any issue and have the same health than OP.
Here is the file I want to put between OP and ED
http://cjoint.com/?EArpJsUWH9y
as I see, it have same properties as OP
so, only ''ED'' is corrupted, but I want to keep it for glue it only the the end of the episode
since I have a lot of episodes and everty time I must glue to it this healthy OP and this unhealthy ''ED'' at the end
Posted: Jan 17 2015, 02:30 PM
Just do it the other way around then - change the 48000 one to 16000
erzane
Posted: Jan 17 2015, 02:33 PM
QUOTE (dloneranger @ Jan 17 2015, 02:30 PM)
ok, I will try it
p.s. pls see the edit I added to my last reply, perhaps it will give you important infos
erzane
Posted: Jan 17 2015, 03:13 PM
I putted both files to 48000 (OP & ED)
but now I cannot append them
same error message
''ED'' is still 23.97602
Posted: Jan 17 2015, 04:00 PM
Take the one that doesn't match and make both the audio and the video the same as the others
If you know the audio format of the others eg mp3 128 cbr 9like your screenshot) then you can directly recompress to that instead of using uncompressed audio
erzane
Posted: Jan 17 2015, 04:10 PM
QUOTE (dloneranger @ Jan 17 2015, 04:00 PM)
for me, reading the MediaInfo is like chinese
can you tell me what should I do with ''ED'' file (exact number to put in the x or y menu) for match with the others ?
if I put my files on AVIFrate it give me that, perhaps it would be more easy to change values here:
OP file
http://cjoint.com/?EArrZzsUxnV
ED file
http://cjoint.com/?EArrZWIc5Zz
9 replies since Jan 17 2015, 01:09 PM Track this topic | Email this topic | Print this topic
