Appending File Doesn't Work
erzane
Posted: Jan 12 2015, 09:17 PM
Hi guys,
I would like to append files with virtualdubMOD 1.5.10.2 (win7)
but when I save (2pass) and go to job control and start it tells me ''error'
can you help me to resolve it ?
regards
Erzane
p.s. I tryed with virtualdub to but no way to have the option ''don't save this job now'' on the saving menu...
Posted: Jan 12 2015, 09:34 PM
It is not immediatly clear what you mean by "append"...
1) Do you like to join two or more files and "glue" them together ?
or
2) Do you like to add one or more files to the jobs list ?
I guess, it is this second question that you struggle with.
The way to add jobs to treat them later, has been changed in VirtualDub (see below).
1) In VirtualDub 10.5.x you can append files by opening the first one and then via the File-menu, Append AVI segment...
or
2) In VirtualDub 10.5.x you can add files to the job list via the File-menu > Queue batch operation... > Save as AVI...
Via File > Job Control, you can go the jobs list.
erzane
Posted: Jan 12 2015, 10:21 PM
Hi
thanks for your reply
by appending I mean:
addign 2 or more file and glue them togheter
after adding them all, I compress them
>video >compression >XvidMPEG4 Codec
>config >1 pass > OK and I go to save and I say to him (don't run this job now)
and I do the operation again with a 2nd pass and save again
and after I go to job control and I see 2files and I say OK
normally it works perfectly (when I had Win XP)
but now with win7 this last operation don't work
p.s. about that:
Menu: File -> Queue batch operation -> Save as AVI...
ok I see now
but it's strange because I don't know why I cannot do it successful with VDubMod and I can do it with VDub.
And the way you introduced to me, I didn't needed to use it when I had winXP..
2 replies since Jan 12 2015, 09:17 PM Track this topic | Email this topic | Print this topic
