Virtualdub Error Code H264, AVI Error code will not open AVI video's
DanT
  Posted: Oct 22 2014, 11:01 PM
Running VirtualDub 1.1o.4 on Windows 7
After installing , ffinputdriver-bin-0.7-32,Deshaker31,
It will now open any AVI video files,,, Oh,, it never did open them..
What do I need to do to fix this..?
I do have a 64 bit computer ,, but running VirtualDub 32
Thank you.
DanT
malky
Posted: Oct 22 2014, 11:11 PM
Are you selecting ffmpeg from the drop down menu before opening the source video.
DanT
  Posted: Oct 22 2014, 11:22 PM
QUOTE (malky @ Oct 22 2014, 11:11 PM)
No I didn't ,,, thank you so much,, I have a lot to learn,, it opened a AVI now..
Please is there a ,,,,, easy way to learn how to work this program>>>? sad.gif
I can't even find how to start to save a video file so I can keep working on it without saving it as a AVI... LOL
Think of me as a 65 year old with my first video camera..
Trying to learn how to take video with a radio control Quad ...
And get the shaky video to stop shaking ....LOL
OH,, yes I did try to read all I could,,, but ,, well ,,, I 'm having a very hard time with it...!!
Thank you again,,,
DanT
malky
Posted: Oct 23 2014, 07:42 PM
Open the file.
If you make changes to the video (deleting frames etc) or use a filter, you have to select a codec before saving the file.
Video > Full processing mode (that's the default).
Video > Compression and select a codec.
VirtualDub saves AVI format;typically you would select 'XviD' as the compressor.
If XviD isn't listed as available, download and install the codec.
http://www.videohelp.com/tools/XviD-Codec
To save, click File > Save as AVI.
DanT
Posted: Oct 24 2014, 04:20 PM
QUOTE (malky @ Oct 23 2014, 07:42 PM)
Open the file.
Thank you for this information...
I will try it..
DanT
4 replies since Oct 22 2014, 11:01 PM Track this topic | Email this topic | Print this topic
