| blaine0002 |
| Posted: Sep 26 2014, 07:33 PM |
Hi all! I have some casts I copied from an NTFS drive and backed up onto a fat32 system, but didnt realize the filesizes got chopped down to 4 gigs until my ntfs drive died. So Now id like to recover the files as best as possible.
I believe i was using MSU lossless codec (it always shows up in programs as SCLS) http://www.compression.ru/video/ls-codec/s...e_codec_en.html Though im not sure what the difference between the msu lossless codec is and the msu screen capture lossless codec http://www.compression.ru/video/ls-codec/index_en.html
when I open a file in virtualdub it rebuilds indexes and then presents me with this
http://i.imgur.com/w48r12Y.png
After I try and hit play I get this error
http://i.imgur.com/3vGKfEz.png
Any tips for recovering these files? |
| Posted: Sep 26 2014, 08:12 PM |
scls is the screen capture lossless codec
Screenshot 1 You need to open the video with extended options and tick the rederive keyframes checkbox to be able to move around the video properly in virtualdub
Screenshot 2 The msu codec is crashing This is probably due to the video being broken, but msu stuff tends to be very crashy at the best of times
Workarounds 1) Try avoiding the end on the file, there may be some garbled data there that's crashing the codec 2) I'm not sure if the ffmpeg plugin can decode scls, but you might want to try opening it with that plugin - might work, might not
| blaine0002 |
| Posted: Sep 26 2014, 08:30 PM |
Tried that and virtualdub crashed again due to scls
http://i.imgur.com/W4KDrnS.png
Out of bounds memory access??? o.O
edit: ok getting somewhere, i grabbed the 64 bit version instead of 32, and now im getting this message http://i.imgur.com/jecSpct.png |
| Posted: Sep 26 2014, 09:35 PM |
Second screenshot just means that virtualdub can't find the msu codec at all Usually because it isn't installed or because you've mixed the bitness up - 32bit programs need 32bit codecs and 64bit programs need 64bit codecs
Out of bounds memory access goes like this ;-) pick a number between 1000 and 2000 ok I'll pick 9 err what? boom! crash!
| blaine0002 |
| Posted: Sep 26 2014, 10:55 PM |
ok so its probably because theres no 64 bit version of the msu codec, so ill go back to using 32 bit vdub.
Any tips on getting around the out of bounds exception? |
| Posted: Sep 26 2014, 11:26 PM |
Unless the ffmpeg plugin can open it then no not really, it's simply that the video data is causing the codec to crash The only cure is to not give the bad data to the codec in the first place, but then you've got no video........ You could try cutting out all the parts that cause it to crash, which could be eg just the last few seconds, or every other frame Possibly you might be able to find an older version of the codec on the net which might not have the same problem?
MSU are repeat offenders for nice software that's buggy and unmaintained I'd strongly advise against using their codecs for anything but temporary files that can be discarded
