Ffmpeg Plugin
larlar
Posted: Aug 12 2014, 02:50 PM
hello its me again...
this time FFMpeg plugin...
i've downloaded this plugin and unzipped it under my virtualdub folder. afterwards, i started virtualdub-1.9.11, clicked onto "open video file", i couldn't find the choice "FFpeg supported files"...
have i looked into a wrong place, or have i set things up wrong again?
under my virtualdub, i have now:
folder: aviproxy
folder: plugins
folder: plugins32
auxsetup.exe
copying
filt
log
readme.txt
vdicmdrv.dll
vdremote.dll
vdsvrlnk.dll
vdub.exe
virtualdub.chm
virtualdub.exe
virtualdub.jobs
virtualdub.vdi
and inside the plugin32 folder:
folder: ffdlls
FFInputDriver.vdplugin
and then inside the ffdlls folder:
avcodec-55.dll
avformat-55.dll
avutil-52.dll
swresample-0.dll
swscale-2.dll
thanks in advance!
Posted: Aug 12 2014, 03:33 PM
Everything's in the right place according to that information
The ffmpeg supported files part is on the 'files of type' dropdown just underneath the filename box at the bottom
Posted: Aug 12 2014, 07:08 PM
Just something important to mention here, is that recent versions of the FFMpeg plugin only work with recent versions 1.10.x of VirtualDub.
In version 1.9.11, the plugin does not show up anymore in the "Files of type".
So, please download and install VirtualDub 1.10.5-test5.zip from here:
> http://forums.virtualdub.org/index.php?act...15&t=22042&st=0
Regards.
Posted: Aug 12 2014, 07:28 PM
@Abrazo
Thanks, I keep forgetting that 1.9.x thing
larlar
Posted: Aug 13 2014, 12:56 PM
alright! i have downloaded 1.10.4, unzipped ffmpeg and the deflickers into it, and all going well now. thanks a million, Abrazo and dloneranger!!
4 replies since Aug 12 2014, 02:50 PM Track this topic | Email this topic | Print this topic
