| Argonaut |
| Posted: Jun 24 2014, 08:41 PM |
Have a 64 bit W7 PC Running 32 bit VD ver 1.10 downloaded latest 32bit plugin of DeShaker (3.0) Open VD Load an avi (confirmed plays fine with MPC) Test run in VD it plays fine > video >filters > add > Deshaker ver 3.0 Select Pass 1 All as per defaults .. only change was to 'tick' append box (as per DeShaker page help comments) >OK then >OK on filter box
On VD Press output screen button to 'play'
It starts, and as expected on output screen shows the motion detect lines & dots. However around 70-100 frames in, the output screen goes black. If I progress to loading again and applying pass2 .... end result in that avi starts to pay then I get message "This frame was not processed in pass1"
I have tried it on several avi clips ... on some of them it fails with same message immediately not after ~100 frames.
I must have something fundamentally wrong ... any clues appreciated. file info for typical avi files shown:.
sample 1 is one that fails after ~100 frames
Format : AVI Format/Info : Audio Video Interleave File size : 133 MiB Duration : 32s 182ms Overall bit rate : 34.7 Mbps Writing library : VirtualDub build 35491/release
Video ID : 0 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.2 Format settings, CABAC : Yes Format settings, ReFrames : 2 frames Codec ID : AVC1 Duration : 32s 182ms Bit rate : 34.6 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 59.940 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.278 Stream size : 133 MiB (100%)
sample 2 is one that fails straight away.
Format : AVI Format/Info : Audio Video Interleave File size : 27.9 MiB Duration : 25s 0ms Overall bit rate : 9 353 Kbps
Video ID : 0 Format : JPEG Codec ID : MJPG Duration : 25s 0ms Bit rate : 9 214 Kbps Width : 640 pixels Height : 480 pixels Original height : 960 pixels Display aspect ratio : 4:3 Frame rate : 30.000 fps Color space : YUV Chroma subsampling : 4:2:2 Bit depth : 8 bits Scan type : Interlaced Compression mode : Lossy Bits/(Pixel*Frame) : 1.000 Stream size : 27.5 MiB (99%) Title : FUJIFILM AVI STREAM 0100 |
| raffriff42 |
| Posted: Jun 25 2014, 12:08 AM |
| QUOTE (Argonaut @ Jun 24 2014, 08:41 PM) | | ...only change was to 'tick' append box (as per DeShaker page help comments) | I have never needed the Append option. From the help page:| QUOTE | | ...Unless the Append to file option is enabled, the log file will be emptied as soon as you start processing in pass 1 | Normally, if you play the video straight through in pass 1, you want to start with an empty log file.
It looks like Append is for advanced processing:| QUOTE | | ...You can use the Append to file option to continue writing to the same log file. You can then change the settings, step a few frames, change again, step some more etc. The frame numbers are written to the log file so you can even go back and redo some frames. If a frame exists more than once in the log file, the last one is used in pass 2. | |
| Argonaut |
| Posted: Jun 26 2014, 01:39 PM |
OK ... append or not the result is same it fails with same error.
Sample 2 I got to work OK (set DeShaker option to Interlace) .. but can't get sample 1 working. |
| raffriff42 |
| Posted: Jun 26 2014, 09:04 PM |
| QUOTE (Argonaut @ Jun 24 2014, 08:41 PM) | It starts, and as expected on output screen shows the motion detect lines & dots. However around 70-100 frames in, the output screen goes black. If I progress to loading again and applying pass2 .... end result in that avi starts to pay then I get message "This frame was not processed in pass1"
Reading this again, it seems to me you should try letting it play all the way through, even if the screen is black. If you stop playback in Pass 1, naturally you will get "This frame was not processed" when running Pass 2.
Another reason for this error (which I have experienced) is because the settings are too strict (or to put it another way, the video is too shaky). Try liberalizing the settings, so as not to reject as many frames. Here's a screen shot I made for a different thread (which is why the Rotation setting was highlighted), but you can see all my settings, albeit dimly (I'm not claiming any special expertise here, remember) https://dl.dropboxusercontent.com/u/1080894...er-rotation.jpg |
| evropej |
| Posted: Jul 1 2014, 08:45 PM |
If you want good results with deshaker, export single file to raw rgb file and then deshake the rgb file. The new version is temperamental. |
