| coucou |
| Posted: Jan 1 2014, 05:19 PM |
Hello,
Until now I used the x32 VirtualDub. Since I started using the x64 latest version I noticed 5 video compression are missed:Codec Cinepak de Radius, DivX 6.9.2 Codec (8Logical CPUs), DivX 6.9.2 YV12 Decoder, MLC v1.2 and VMnc v2 (see the here bellow image)
1) What the benefit I get by using the 64 bits version? 2) Is any way to get the DivX 6.9.2 video compression in the 64 bits version? Regards
| Posted: Jan 1 2014, 06:14 PM |
64bit apps need 64bit versions of codecs, filters etc So you'd have to download and install the 64bit versions if they are available
The only benefit is a possible speed increase
| coucou |
| Posted: Jan 2 2014, 10:34 AM |
TNX dloneranger  So, Does DivX codecs are available in 64bit version? Regards |
| Posted: Jan 2 2014, 01:37 PM |
AFAIK no XVid does though
| coucou |
| Posted: Jan 3 2014, 12:44 PM |
TNX again dloneranger  So, where do I find XVid 64 bits? |
| raffriff42 |
| Posted: Jan 3 2014, 01:32 PM |
https://www.google.com/search?q=XVid+64+bit |
| coucou |
| Posted: Jan 3 2014, 01:47 PM |
Got it Thank you |
